| FlightRisk |
 FlightRisk Spanner Monkey
 Posted: 15:06 - 27 Jul 2014 Post subject: Check oil warm or cold? |
I freaked out for a second when I checked my oil, and there wasn't any!
Then I realised you put it on the centre stand and then check, so I left it for a while, checked it again and it was at the minimum line.
This is checking cold though. Will the level go up when it's warm because the oil is thinner and will run down to the bottom more easily, or will it go down because it's pumped up around the engine?
I don't want to run it round the block to warm up with critically low oil.
(Running it at home will immediately summon a grumpy weird man from across the road. Apparently a motorcycle idling bothers Mother... ) |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 15:08 - 27 Jul 2014 Post subject: |
What bike?
If it's a wet sump bike, then you can check it when cold. If it's a dry sump bike then you have to check it slightly differently.
Chances are yours is wet sump. You are checking it on level ground as per the manual instructions right? ____________________ My Flickr |
| FlightRisk |
| Wafer_Thin_Ham |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| FlightRisk |
 Posted: 16:23 - 27 Jul 2014 Post subject: |
You absolute star! Thanks!!!  |
The last post was made 11 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
