CPU heat problems.
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2, 3  Next
Hetzer
PostPosted: 11:57 - 13 Jul 2014    Post subject: CPU heat problems. Reply with quote
First experienced in game#1, the PC would freeze with a continuous high-pitched scream from the speakers on hot days (20c). I put it down to a code issue in the game but yesterday it happened in game#2.
I have a Corsair H50 water-cooler and my BIOS monitor tells me the pump is working ok and the rad-fan certainly is. After re-doing the thermal paste yesterday the temp is worse. In a 20c room at idle (1600mhz to 2000mhz) on 3% load I'm seeing 45~55c. Using Prime-95 the temp immediately shot to 90c+ and would have gone higher if I hadn't terminated the prog.
My rig seems to be functioning ok in non-game use, which tells me the CPU isn't damaged but I'm wondering this...is it possible, having had the CPU over-heat to the point of freezing my PC several times, it can now be running much hotter due to damage? Or is it possible the pump has failed in the cooler but the BIOS still gives a reading for RPM? If the pump isn't connected to the CPU-fan header on the mobo I get a boot-up alert telling me so. Otherwise the BIOS is telling me 1400rpm or so.
I've been fixing PCs for over a decade and have never before come across anything like this, hence my asking here. TIA for any input. I'm thinking new cooler or new CPU.
The Artist
PostPosted: 11:58 - 13 Jul 2014    Post subject: Reply with quote
What processor is it?
CaNsA
PostPosted: 11:59 - 13 Jul 2014    Post subject: Reply with quote
Graphics card temps?
Hetzer
An Intel i5 2500k (Sandybridge).
Hetzer
PostPosted: 12:01 - 13 Jul 2014    Post subject: Reply with quote
They're good. PC crapped out the last time with the card (GTX780) at 75c.
CPU is currently around 48c, just this browser running. Badly wrong.
CaNsA
PostPosted: 12:02 - 13 Jul 2014    Post subject: Reply with quote
Overclocked at all?
CaNsA
PostPosted: 12:06 - 13 Jul 2014    Post subject: Reply with quote
Also, are you utilising the i5 Intel HD Graphics 3000 in tandem with your graphics card?
lihp
PostPosted: 12:10 - 13 Jul 2014    Post subject: Reply with quote
Is the radiator clean?
it also seems as though mobo is reporting fan speed on the radiator so it can still be possible that the pump has failed.
Do you have an air cooler lay around that you can throw on it as a test? If you don't get same temp issues then you may have a prob with the cooler. Not sure how you would test the pump in a sealed unit though
Hetzer
PostPosted: 12:15 - 13 Jul 2014    Post subject: Reply with quote
The CPU was turboing up to 4300ghz but I now have it maxing out to 3700ghz (which it doesn't come close to while using only the browser).
No, the onboard graphics are not being used. I think that's available only on the i7 series anyway?
The pump is connected to the CPU-fan header on the mobo. The rad-fan is connected to a chassis-fan header. Both are showing healthy RPM in the BIOS and I've turned off q-fan, to force them both to do max RPM continuously.
My air-coolers are not available presently (will be tomorrow).
The rad is spotless, I gave it a thorough cleaning a few days ago. No crap anywhere, including between the fins.
CaNsA
PostPosted: 12:23 - 13 Jul 2014    Post subject: Reply with quote
What thermal paste are you using?
Did you put enough on?
Are you sure the block is seated correctly?
Do all cores heat up evenly?
Grab openhardwaremonitor (if using windows) and watch the core temps.
https://openhardwaremonitor.org/
Hetzer
PostPosted: 12:32 - 13 Jul 2014    Post subject: Reply with quote
I used a syringe from Asus (came with my last mobo). My Arctic Silver is locked away over the weekend. I used about two grains of rice' worth. The block is properly seated.
Yes, all cores temp evenly.
I suspected the old paste was dried out but when I removed the block it was still 'fluid' (not dried out). So it should still have been working ok (was Arctic Silver).
I'm thinking maybe the pump is no longer working but is still sending a signal to the BIOS saying it is. I can also feel a vibration in the pipes, like water is moving or the pump is vibrating the pipes.
So it's not possible the CPU would still be working ok in terms of processing data but damaged enough to run hotter than it should?
Hetzer
PostPosted: 12:34 - 13 Jul 2014    Post subject: Reply with quote
I'm going to take the CPU out and do what I used to do, spread the paste evenly over the die instead of putting a blob in the middle.
CaNsA
PostPosted: 12:35 - 13 Jul 2014    Post subject: Reply with quote
It's possible.
There have been reports of the thermal compound under the CPU lid of getting borked though.
Depending on how this plays out, you might find yourself having to de-lid.
Fun times.
Hetzer
PostPosted: 12:36 - 13 Jul 2014    Post subject: Reply with quote
CaNsA wrote:
It's possible.
Fun times.
I think that's an issue only with the new Haswells (which they've now fixed).
Hmm...possible the over-heats have fried the compound under the lid I guess.
CaNsA
PostPosted: 12:48 - 13 Jul 2014    Post subject: Reply with quote
Also, just to rule stuff out.
Do a CMOS reset.
Question, have you unparked all cores?
PostPosted: 13:17 - 13 Jul 2014    Post subject: Reply with quote
The problem occurs when you run prime95 or intel burn test?
The H50 is a PoS in my experience, the pump decided it was happier to not work all the time. Trying a different cooler would be much first step, if not just to rule out the H50 as being the culprit.
mathewculver
PostPosted: 13:25 - 13 Jul 2014    Post subject: Reply with quote
I run a computer repair shop and I can tell you now, don't spread the paste yourself. On bigger cores, a pea size shape in centre of the chip will be perfect. I've used cheap and expensive pastes before and as long as you use a grain of rice on smaller cores and A pea on larger core covers then it will be spot on.
CaNsA
PostPosted: 13:29 - 13 Jul 2014    Post subject: Reply with quote
Join Forum
Uses real name.
Pass the popcorn
PostPosted: 13:33 - 13 Jul 2014    Post subject: Reply with quote
Putting a pea sized amount or a blob the size of a couple of grains of rice is a really vague way to get the thinnest possible layer of thermal paste that evenly covers the whole cpu.
"I recently commented on the underhand tactics of other companies yet left it anonymous in the hope it wouldn't happen again, I have now had yet another customer contact me saying that once again, he had contacted a customer by private message informing them that he/his company could do it cheaper. So if anyone that has requested a repair from Speedy I.T. receives a message from Mathew Culver or Prism Technology please let me know. In this day and age we all have to be competitive, but to do that is just a shame. To think that I have been fairly helpful to him since they reopened and for him to do that makes the saying "there is no friends in business" ring true."
Hetzer
PostPosted: 13:34 - 13 Jul 2014    Post subject: Reply with quote
Fucking ASUS paste, utter unmitigated SHITE. Upon trying to spread it I discovered it turns to clay after a few seconds exposure to the air.
Then I found a little sachet of the white generic stuff which spread beautifully. I'm now around 60c at 3.4ghz running Prime, which isn't particularly good but at least I now know the CPU is ok. Idles around 30c (used to do 25c but that might have been in the winter in an un-heated room).
I'm going to order a new cooler, the Corsair Hydro H110 most likely.
Thanks for the help guys. Thumbs Up Karma
gsxfdumb This post is not being displayed because the poster is banned. Unhide this post / all posts.
Hetzer
PostPosted: 13:37 - 13 Jul 2014    Post subject: Reply with quote
I spread the paste for years until I figured there was little advantage to it vs the blob in the middle. Never caused any problems other than perfectionist burn-out.
CaNsA
PostPosted: 13:50 - 13 Jul 2014    Post subject: Reply with quote
Please tell us why you have joined this motorbike forum?
Hetzer
PostPosted: 14:01 - 13 Jul 2014    Post subject: Reply with quote
I'm getting 73c on one core while another's hitting 81c (now running Prime at 4.3ghz). Is that kind of differential normal? Same spread at idle etc.
CaNsA
PostPosted: 14:15 - 13 Jul 2014    Post subject: Reply with quote
one of mine always heats up a little more than the others.
Parked/unparked cores?
The last post was made 12 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 127.61 Kb
