Replacing bent fork stanchion
base
PostPosted: 18:10 - 25 Jul 2014    Post subject: Reply with quote
With that kind of damage I would personally want to know if the head stock was still "true" before I started spending money on it.
PostPosted: 18:12 - 25 Jul 2014    Post subject: Reply with quote
Some would. I'd just grab a new front end. R6 front end for fun.
gavcarter
PostPosted: 01:13 - 26 Jul 2014    Post subject: Reply with quote
Google fork straightening service and similar, you should be able to find some one local enough to do it for you, or give it a bash your self just for fun Thumbs Up
TUG
PostPosted: 04:26 - 26 Jul 2014    Post subject: Reply with quote
I've bent some forks in my time, you will have damaged the damper rod and bent the top and or bottom yoke, depending how hard you hit the van the headstock bearings will be nicely fooked and possibly the front wheel bearings too.
When it comes to fixing a crashed bike, get the parts thoroughly inspected and replace if off, you might find some straight forks but if the headstock and clamps are fucked it will turn one way better than the other in a straight line. Laughing
Haz ER-5, innit!
Robby
Dirty Old Man
PostPosted: 10:08 - 26 Jul 2014    Post subject: Reply with quote
Pull them apart and see. The damper rod should be entirely enclosed by the fork lower, which looks fine. The bent bit only has the spring in it, and it doesn't look like enough of a bend in the fork to damage or compress the spring.
I wouldn't go with straightening on those forks, once you have a crease in the metal it's seriously weakened.
gavcarter
PostPosted: 11:27 - 26 Jul 2014    Post subject: Reply with quote
Very good point I didn't see that! Although who ever you took them to would have told you anyway....
Blue_SV650S
PostPosted: 12:14 - 26 Jul 2014    Post subject: Reply with quote
Your yokes are going to be bent too ...
TUG
PostPosted: 14:12 - 26 Jul 2014    Post subject: Reply with quote
Robby is correct, I thought these had an adjuster at the top but my memory was incorrect.
https://www.yamahamotorcyclespares.co.uk/spares/epcimages/13040/26.jpg
Haz ER-5, innit!
mattsmith95
PostPosted: 14:58 - 26 Jul 2014    Post subject: Reply with quote
Get new from WEMOTO, mind you it will NOT be cheap.
nathan k
PostPosted: 16:25 - 26 Jul 2014    Post subject: Reply with quote
Too right, after lots of head scratching replacing my bent forks and why the wheel wasn't straight I tried a new top yoke and suddenly it all fitted perfectly.
There was no visible sign of the yoke being bent, it doesn't take much to shift the wheel out of line.
My bet is on the top yoke being bent, the bottom should be fine.
TUG
PostPosted: 17:15 - 26 Jul 2014    Post subject: Reply with quote
MC wrote:
Thanks for the advice everyone. New forks are £400 each, a new stanchion is £110ish, and I'll probably attempt to do the job myself (even though the Haynes manual says it's a four spanner job Smile).
Quick question, the Haynes manual doesn't mention any special tools for reassembling the forks, yet the service manual does so do you really need them? I know some people say they use a bit of scaffold pole etc.
Not had a problem just using hand tools and when I worked at yamaha we just buzz gunned the nut off the bottom to make it easier, if it does spin when you try to tighten it back up, just use the springs pressure to help hold it in place, as you can see from the parts diagram they are very basic so wouldn't really need special tools, HOWEVER, if you do get the holder tool cheap point me to it because they're good to have for kawasaki forks.
Haz ER-5, innit!
TUG
PostPosted: 19:39 - 26 Jul 2014    Post subject: Reply with quote
Vincent wrote:
The only special tool I'm aware of is the one to hold the damper rod while undoing the bolt.....not strictly necessary tho.
There must be a pair of used forks somewhere.....you tried loads of breakers...and abroad?
Yamaha didn't sell a lot of these so I would imagine the parts are rare, especially ones like forks. Probably best just to get the stanchions and bung them on.
Haz ER-5, innit!
Eddie Hitler
PostPosted: 02:20 - 27 Jul 2014    Post subject: Reply with quote
Bend the other fork to the same spec as the damaged one, then it should ride fine.
PostPosted: 23:11 - 27 Jul 2014    Post subject: Reply with quote
I'd take them apart BEFORE ordering new stanchions.
It's been a hell of an impact and you might find part of the lower has cracked too. I've had the spindle clamp crack through on a bike following a big frontal impact.
Worth checking the wheel is still true and uncracked and the wheel spindle isn't bent.
PostPosted: 19:44 - 18 Jan 2015    Post subject: Reply with quote
Not sure I would pay £175 for pitted forks. Wemoto have new pattern for tubes for £112 each
J.M.
PostPosted: 20:17 - 18 Jan 2015    Post subject: Reply with quote
Don't restrict yourself to eBay. I found my replacement forks from somebody in the states that was breaking a bike, on a forum. Postage over here was a bit expensive, but the forks were good condition, and it wasn't able to find any in the UK at the time!
2004 R1 & 2018 XSR900
The last post was made 11 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 128.77 Kb
