Yamaha DTR 125 Clutch Release Point?
Boxing
PostPosted: 16:25 - 02 Aug 2014    Post subject: Yamaha DTR 125 Clutch Release Point? Reply with quote
Hi all.
When I pull the clutch in at the lights it starts rolling forward, and I have to apply the back brake, then it begins trying to stall. So the biting point of the clutch is out.
I've put a new clutch cable on, tried adjusting it to put some slack in, and same problem.
When I put it in gear with the engine off and push it forward, it's like having the clutch completely out.
I can't seem to figure out why it won't adjust. Also, two of the plates stick together as seen in the video below:
https://www.youtube.com/watch?v=8XDy4wkW_SQ
I'm told they're fine and shouldn't stick when there is transmission oil in. Is that true?
Edit:
It's also near on impossible to get into neutral. I have to turn the engine off in order to put it in neutral or get into neutral as I'm rolling to lights etc, when stopped it won't enter unless the engine is off. Rolling Eyes
joshuaHolden
PostPosted: 00:56 - 06 Aug 2014    Post subject: Reply with quote
Have you replaced the gear oil, what did you use if so?
The last post was made 12 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.02 - MySQL Queries: 14 - Page Size: 31.47 Kb
