XJ900 Renntec Rack + Givi E450 topbox
mgh0
PostPosted: 18:47 - 14 Aug 2014    Post subject: XJ900 Renntec Rack + Givi E450 topbox [FOR SALE] Reply with quote
Rack no longer needed as I have a Wingrack fitted. In reasonable condition, few scrapes, comes with mounting hardware which replaces your pillion grips which could do with a lick of paint. £90 new, yours for £50 posted. If you are in/around Birmingham you are also welcome to collect.
https://i298.photobucket.com/albums/mm265/megah0/36031C4A-031E-473C-8BFE-FB996F336260_zps3bmmpqqt.jpg
https://i298.photobucket.com/albums/mm265/megah0/656C7A4B-E36D-4E5F-B963-7A6A379BE1D1_zpsd31rlirl.jpg
Givi E450 top box in good condition, the rear reflector fell off yonks ago (internal lugs broke) so has been glued in (slight yellowing on the edges of the reflector). The white mark on the top is some Gaffa tape residue which I am slowly chipping away at (used tape to ensure the key didn't get lost). Comes with mounting plate, again with all the required fixings. I have the plastic top plate for it as well which hides the bolts.
https://i298.photobucket.com/albums/mm265/megah0/B2A6AA8B-FE61-418D-8B0C-17C230257612_zpshgz35qnk.jpg
https://i298.photobucket.com/albums/mm265/megah0/53B52066-AB02-4122-9849-E74056580FB8_zpsdhrmmqfs.jpg
https://i298.photobucket.com/albums/mm265/megah0/C6865749-715D-468D-BF44-1B7F075284E6_zps076jva2z.jpg
https://i298.photobucket.com/albums/mm265/megah0/8E0A5F6E-F787-4587-8CDE-DD4A58193B5C_zpsd4seaoif.jpg
Due to the weight I'm after £80 posted for this with the base plate.
Will do a deal if you want the lot!
Cheers.
"Courage is not defined by those who fought and did not fall, it is defined by those who fell and rose to fight again." Adrienne Rich.
The last post was made 11 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.19 - MySQL Queries: 14 - Page Size: 29.6 Kb
