| Diggs |
 Diggs World Chat Champion
 Posted: 17:21 - 17 Aug 2014 Post subject: Bleeding brakes!! |
I can't get a 'hard' out of bleeding my brakes. Whatever I do the lever just keeps coming back to the bars. They were fine beforehand, no obvious leaks, so common sense says to me I have air coming back into the system through the bleed nipple. Anybody else had this problem and been able to solve it? I am not a mechanic so I'm sure it is something I am doing wrong.... ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
| Diggs |
 Posted: 17:23 - 17 Aug 2014 Post subject: |
Oh, my brake-bleeding it consist of what it has done so for the last 30 years - a length of battery pipe and an empty Export tin. Perhaps I need to invest in one of these newfangled kits? ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
| J4mes |
 J4mes World Chat Champion
| Diggs |
 Posted: 17:31 - 17 Aug 2014 Post subject: |
Sorry, not been clear - tin not empty now.... I've bled brakes this way since I started messing with bikes over 30 years ago and never had this problem before. ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 18:38 - 17 Aug 2014 Post subject: |
My technique:
Ring spanner on bleed screw.
Then pipe on and the other end of pipe submerged.
Pump lever a couple of times and release bleed screw whilst squeezing lever. Nip the bleed screw before the lever touches the bar.
Repeat until done.
Tie lever back with a zip tie and leave overnight.
Process is slightly different if I'm starting with an empty system...I'll tap the brake lines and banjo to release trapped air bubbles and won't nip the bleed screw between lever pumps until the system is nearly full. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Wull |
 Wull Crazy Courier
| bugeye_bob |
 bugeye_bob World Chat Champion
| el_oso |
 el_oso World Chat Champion
| kramdra |
 kramdra World Chat Champion
| blackbosh |
 blackbosh Nova Slayer
| Rogerborg |
 Rogerborg nimbA
| Diggs |
 Posted: 07:45 - 20 Aug 2014 Post subject: |
Managed to bleed brakes after half an hour of trying. Spent ages with no fluid coming out, then a dribble, then none again. Eventually I got fluid with bubbles and my hand was aching before the lever went hard... ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
The last post was made 11 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
