| Author |
| Paul2129 |
 Paul2129 Nova Slayer
 Posted: 22:32 - 30 Aug 2014 Post subject: Diagnose this electrical fault, flickering lights / no start |
Hi guys, I'm hoping you can diagnose this problem. I bought a CG125 a couple of years ago now, it is a 2006 and has 18,000 on the clock. When I bought it, the battery was knackered, the starter would barely turn over, it went very slow, but was fixed when I replaced the battery. This has been fine for the last 2 years and 9000 miles. I bought a new bike and use this one around once a week or so.
I found that the starter would just click and there was no action from the starter (once every 20 presses it would start like normal) I charged the battery ( my Optimate indicated no battery issue) but the starter still just clicked. I kept using the bike by bump starting it while I planned to make time to try and fix what I thought was a gummed up starter motor (seen a fix for it on YouTube)
Today I took the bike on a 70 mile ride up the motorway, left it parked up for a while and came to ride it home in the dark. I find that all the lights flicker, indicators pause, glitch, or flash slowly, and the instruments are flashing randomly dim to bright, it's not in relation to engine revs.
I didn't check voltage at the battery, or what it's doing when it's charging. I will do that tomorrow and report back
Can anyone comment on what they think this is ?
Maybe high revs on this long ride caused the reg/rec to under/overcharge the battery to start these weird symptoms ? But if that's the case, why wouldn't fully charging the battery make the starter work ?
Please post your thoughts, I'll report back with voltages tomorrow
Paul |
| Back to top |
| Wull |
 Wull Crazy Courier
| Back to top |
| WD Forte |
 WD Forte World Chat Champion
| Back to top |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 09:47 - 31 Aug 2014 Post subject: |
I would:
1. Check battery voltages off the bike, before and after a charge.
2. Check resistance of alternator windings (usually 3 coils to check).
3. Check resistance across switches (whilst battery is off).
4. Check battery voltages on the bike, with engine off, and engine running @ 2000rpm.
5. Check all earth connections.
Might be a Reg/Rec problem? ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Back to top |
| Paul2129 |
| Back to top |
| Taught2BCauti... |
 Posted: 10:52 - 31 Aug 2014 Post subject: |
12.2v with the engine off sounds a bit low - is it the same when disconnected from the bike?
A good battery will hold over 13v after being charged, but if it drops down to 12.2v when re-connected, then something must be drawing current.
If there's nothing switched on, a faulty Reg/Rec could cause current to flow back through the alternator windings.
I had a similar problem on a car a few years ago - I charged the newish battery off the car, but after re-connecting it, the voltage dropped below 12v after 30 minutes. As I was checking the wiring, I noticed the alternator was quite warm even though the engine hadn't been running. Replaced the Reg/Rec (part of the alternator on most cars, but a separate unit on bikes) and that fixed it. ____________________ Honda Varadero XL125(V8)
| Back to top |
| Paul2129 |
| Back to top |
| Taught2BCauti... |
| Back to top |
| Wull |
 Wull Crazy Courier
| Back to top |
The last post was made 11 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
