Biker au |
Biker au L Plate Warrior
_mjs_ |
_mjs_ Could Be A Chat Bot
Biker au |
Taught2BCauti... |
Taught2BCauti... World Chat Champion
Biker au |
Taught2BCauti... |
Posted: 10:12 - 01 Sep 2014 Post subject: |
A speed limiter of some sort is the only explanation for your problem that I can think of.
If your bike does have one, and I think there's a good chance it does, it might not be working properly - causing the problem to occur at a different road speed. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
Biker au |
DOS |
DOS World Chat Champion
Vincent |
Vincent Banned
Posted: 15:35 - 01 Sep 2014 Post subject: |
+1, speed restrictor is electronic and on the speedo pcb
There may be some more details and pics on the Grey Bike Forum. ____________________ Space Is Deep |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 17:10 - 01 Sep 2014 Post subject: |
If its an electronic speed-limiter, it'll retard the ignition at whatever speed its set to, regardless of rpm's.
6th gear will be an over-tall ratio or 'over-drive' to knock the revs back for more relaxed cruising, and in all liklihood, on a bike with only 40bhp or so, all stacked at higher rpm's it IS likely to go 'faster' in 5th, where lower ratio will let you rev to where peak power is made.
Think about it; 40bhp, will just about get you to about 110mph on a good day, but to do it you'll need the motor spinning pretty much bang-on peak-power revs, what, 12,000? But to hold 70mph only needs about 12-15bhp, which you probably have from anywhere above 3,000rpm. If 'top' gear was geared to deliver 110mph at 12,000 revs, then 70 would fall at 7,500rpm, and would still be rather 'buzzy'. So putting a taller gear over 'top', an'over-drive', could drop the revs at 70 back to perhaps, 5,000, just before it starts to get 'busy'... but that would imply nearly 170mph at peak power.... but, with only 40bhp, you are never going to be able to do 170.
But, this is why bikes like this with peakpower made with a lot of rpm's will have six-speed gearboxes, not five, and you will need to use the lower gears more to get at that high rpm power, so stirr the box, so to speak. Something that can be rather alien if you have come from a DAS bike with a broad flexible power delivery; slightly less so if you have come from a 125, that with limited power can need the gears worked a lot to get at what they have, but which tend to have 'top' matched pretty closely to best speed their power can pull, without an 'over-drive', as they don't have any excess power to hold 'higher-speeds' with less revs.
Or short.... COULD just be the 'nature' of the bike...a small displacement, high-reving multi, and absolutely nothing to do with power or speed restrictions... its just a rev-happy bike. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Kickstart |
Kickstart The Oracle
Biker au |
Biker au |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 06:37 - 02 Sep 2014 Post subject: |
Pberm wrote: | One strange thing though to suggest it is not a limiter is that it goes above that speed in 5th gear up to 120-130kph just can't hold revs in 6th, so would suggest it's something associated with that gear instead of just top speed, or if the limiter is only active is 6th perhaps? |
This is the power Graph for a bike like yours.
https://tyga-performance.com/tyga_rydas/Tyga_Vs_Std_Dyno_Sheet_Custom.jpg
Data-Sheet for your bike says it ought to do about 180Km/h.
If it's geared to put 180Km/h at or close to 10,500rpm where it has the power to go that fast, that means that the final drive ratio gives aprox 1.72Km/h per 100rpm.
OK, so at 130Km/h, in 6th your engine should be turning something like, 7,500rpm... now look at the power graph and see how uch power its making at that engine revs. Its barely 20bhp.
Go slower still, 110Km/h were your bike is 'playng up'... aroud 6,300rpm... and you have around 18bhp to play with.
This is a peaky little, rev hungry motor that has to have the knackers thrashed off it to get the high rpms where big bhp is made. Low down, under 7,500rpm its flat as a fart and has barely the power of a 125... which is JUST enough to do 110Km/h or so.
Power is Force times Speed. So to go faster you need more force; BUT you eed that force to over-come wind resistance, and that goes up with speed, so to go twice as fast, you need more than twice the power... which you have... BUT, you cant get at it, cos you are in too high a gear, too early.
Change down to 5th... and as you have found... you go faster... 120-130Km/h. trouble is, that STILL doesn't get you up to the revs n 6th where the engine's making significant power; its still under that 7,500rpm pot where the power ramp starts, and the power starts riding quickly with revs, and you probably only just have enough to hold the speed you've achieved.
If you revved the thing out to the red line in 5th, it'll probably run t spmething like 160Km/h or more; and if you upshift to 6th then, it will drop you oto the power curve at arou 9,000rpm, where you have somethig like 45bhp to play with, and on a portion of the power ramp where the power is increasig faster with engie revs than wind resistance is increasig wth road speed, allowing you to continue accelerating, probably not very fast, but still accelerating all the same to the bikes notional top speed or 180Km/h, at 10,500rpm, where the power curve hooks and starts to drop off, and the bike's 'topped out' and wont go any faster... OR it'll let you hold the road speed you shift up at, wth less revs than you used n 5th to get there.
As I tried to explain before, this sounds pretty 'normal' for a bike with a small displacement and reletively 'peaky' egine that likes to be revved to get at where it akes its useful power, with a reletively tall 'over-drive' top gear.
110Km/h, in 5th is just not high enough up the power ramp to need 6th to drop the revs for more 'relaxed' cruising speed, cos even in 5th you aren't high eough up the rev rage for it to have got 'busy', its probably still under that 7,500rpm turning-point where the power starts to come in.
Bikes 12 years old. Could be it is lacking some 'sparkle' from wear and tear damping it'sperformance a little, makig the effect more pronounced; BUT, this DOES sound like it's just the nature of the bike.
It would be incredibly strange for a bike to have some sort of artificial speed limiter that only works on 6th gear, when the bike obvousely goes faster in a lower gear!
Could be some-one's dicked with it; who knows what or why some people do daft thigs to thier bikes...
BUT, my first 'test' would simply e to try reving the nuts off the thing to the red line i each gear before trying to change up... these ARE rev hungry little bikes, and I suspect you'll find that if you max it out in 5th it'll be a LOT happier when you shift to 6th and is likely to hold or even continue accelerating beyond whatever you get to in 5th when you do. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Taught2BCauti... |
Posted: 11:31 - 02 Sep 2014 Post subject: |
Found this on the website I mentioned in my first post, referring to OP's model:
Quote: |
IS YOUR BIKE RESTRICTED?
probably, Its easy to find out how.
In other bikes or a faired version its the dash fuse.
Just remove the fuse for (its 1 fuse mine is a 10Amp);
"meter, tail light, horn, turn, stop light, neutral light, hazard".
Then ride the bike, carefully!
remembering you have no indicators, no rear lights, no neutral light, no horn.
It should misfire at 5500 RPM, and believe me its noticeable.
If it doesn't misfire your bike has been derestricted already. |
Vincent |
Vincent Banned
GeorgeB. |
GeorgeB. Crazy Courier
Kickstart |
Major Doss |
Major Doss Traffic Copper
Posted: 02:47 - 03 Sep 2014 Post subject: |
Have a look in this month's Practical Sportsbike, they have a feature on derestricting the restriction in the restrictive speedo.
tl;dr E Gads, Tef man! You do waffle some utterly useless bollocks, sometimes! keep it up. |
wr6133 |
wr6133 World Chat Champion
cb1rocket |
cb1rocket World Chat Champion
Posted: 08:21 - 03 Sep 2014 Post subject: |
Does it not hold any speed in 6th? Or is it clunky? Sounds like transmission has gone to me.
I own a cb1 and yes the speedo limiter kicks in at 180kph, easily bypassed. Feeding a live into the sensor will disable it ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
Biker au |
wr6133 |
There is a gap of 2 years, 234 days between these two posts... |
tarlowb |
tarlowb L Plate Warrior
Posted: 12:11 - 25 Apr 2017 Post subject: |
Biker au! ('')
I have this exact bike, exact year and unfortunately...exact problem.
Have you found a solution to this? I presume you either fixed it, or sold it/scrapped it! there has been no action on the post for over two years. I have narrowed it down to either a problem with the JDM restrictor, or transmission failure.
obviously its going to cost a bomb to rebuild a transmission and I don't want to start off down that route if its not necessary.
I am looking under the clocks this weekend to investigate, but a few days ago I replaced the headlight bulb. hoping I've just knocked something out of place as it was fine before!
lovely bike when it works ('')
any help would be insanely appreciated! |
tarlowb |
The last post was made 7 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
