nsr125 clutch problem
bren
PostPosted: 14:02 - 14 Sep 2014    Post subject: nsr125 clutch problem Reply with quote
Hi Guys,
I have following problem with nsr.
Starts OK ... neutral light on and side stand light on
side stand up and light out
clutch in and down to first ... bike jumps forward and stalls
I replaced the gear oil and still same problem
Tried pushing it up hill to jump start and works ok ... can change gears when riding but pulling in clutch wont disengage gears completely and bike stalls at low speed.
Is this just cable adjustment or something gone bad with clutch.
Thanks for any help
Bren
alains
PostPosted: 17:06 - 14 Sep 2014    Post subject: Reply with quote
first check the clutch lever then check cable and adjust .after adjusting the cable , if nothing has changed you will need to dismount the clutch . control the friction disks (5+1) thickness , change the 4 springs (22401KY4900) and eventually the friction disks
FlightRisk
PostPosted: 17:56 - 14 Sep 2014    Post subject: Reply with quote
There will be a cable tension adjuster on the lever and another one at the other end of the cable.
There should be about 10mm of free-play measured at the end of the clutch lever. Try that first anyway.
And maybe check the chain tension as well just to rule that out.
Honda CB500S
The last post was made 12 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 35.01 Kb
