First Gear Hard To Select
uk_ryan
PostPosted: 19:55 - 20 Sep 2014    Post subject: First Gear Hard To Select Reply with quote
Hi,
Changed the clutch on the rs 125 , finding it hard to select first from neutral (will sometimes go in), it seems ok up and down the gears and finding neutral is no problem. I set the clutch up as per the manual but thinking it might need to be adjusted,any thoughts ? not disengaged enough? thanks
Taught2BCauti...
PostPosted: 08:19 - 21 Sep 2014    Post subject: Reply with quote
Was there much difference in the combined thickness of the plate stack before and after (old v new)? When changing bike clutches, I always check this to make sure I have the correct plates.
Did you check the actuator spindle for wear?
Could be oil drag, but try adjusting until it just starts to slip in top gear, then back off a bit and try 1st again.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
uk_ryan
PostPosted: 19:55 - 21 Sep 2014    Post subject: Reply with quote
thanks for the help.
The last post was made 12 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 14 - Page Size: 34.82 Kb
