| Val |
 Val World Chat Champion
 Posted: 21:45 - 30 Mar 2015 Post subject: IAM U turn the right way with controlled front brake |
I present you IAM U turn - correct way to do it with just a pinch of a front brake
https://www.facebook.com/video.php?v=786831904743186 ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:51 - 30 Mar 2015 Post subject: |
He's clearly not heard of Windows movie maker.
Can skip the whole first minute and a bit. ____________________ My Flickr |
| Doovy |
 Doovy World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| cheeseman |
 cheeseman Trackday Trickster
 Posted: 09:59 - 31 Mar 2015 Post subject: Re: IAM U turn the right way with controlled front brake |
How embarrassing! But why do you say IAM? It looks like Police rider training to me. ____________________ XJ600S->Sprint ST 955i * ; Now ST1100 + W650 |
| Skudd |
 Skudd Super Spammer
| lihp |
 lihp World Chat Champion
| Skudd |
 Skudd Super Spammer
| barrkel |
 barrkel World Chat Champion
 Posted: 16:50 - 31 Mar 2015 Post subject: |
| Quote: | I've only experienced linked brakes once, but can you correct me if I'm wrong?
I believe that the brakes are only linked when using the front, and that if you use the rear, then ONLY the rear is used? |
There's no one single system. On Honda scooters with linked brakes, there's typically three pistons on the front caliper and one piston on the rear, the front brake applies two pistons on the front, while the rear brake applies one piston on front and one piston on rear.
On the VFR, it's much more complicated. All the brakes have three pistons per caliper. The rear brake applies two pistons on rear and one piston on the front left caliper. The front brake applies the 5 remaining front pistons, but the left hand caliper is able to tilt in its mounting. This tilting action is only actuated when the brake is applied and gripping the disc, so that the forward motion tries to rotate the caliper. The tilting action applies pressure to a slave brake cylinder, which in turn actuates the remaining piston in the rear brake caliper (not directly though, oh no, it's mediated by a PCV, "proportional control valve").
Thus, on the VFR, if you apply the rear, it's mostly rear, but also some front, which is also able to feed back into the rear. If you apply the front, it's almost all front, but a little bit gets fed back into the rear. You get most braking power by using both simultaneously.
https://jay-d.com/ecto/brakebleeding/Part1-2.jpg
The rear brake on the VFR is a bit theoretical though. The swingarm presents a large surface for chain oil to soak onto, if not from fling, then from the chain guide / swingarm protector. The rear brake caliper is mounted underneath the swingarm, and chain oil tends to spread down there. After a long tour with scottoiler, my rear brake caliper, pads etc. are invariably coated in oil. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 20:26 - 31 Mar 2015 Post subject: |
| lihp wrote: | | Skudd wrote: | Someone posted about linked brakes being the cause, I don't think so myself. However I use the front on most of my U-turns unless really messy roads/tracks. I also have linked brakes. |
On my first x11 I boiled the brakes limping it home with the rear brake wedged on.
Quite annoying it was. ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| Vracktal |
 Vracktal World Chat Champion
| lihp |
| Albigularis |
 Albigularis World Chat Champion
The last post was made 11 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
