nx650 barrel stuck, advise/experience welcomed
pikey666
PostPosted: 18:08 - 02 Nov 2014    Post subject: nx650 barrel stuck, advise/experience welcomed Reply with quote
I have a nx650 that ran low on oil and now has a knock and is a little smokey.
I am trying to remove the barrel so I can check the piston rings, bore etc. I have removed the head bolts and smaller side bolts at which point the honda service manual say simply lift the barrel off.
Not a hope of that, I have tried some gentle persuasion with a rubber mallet but still no movement.
Do I need to heat the gasket area to loosen it and if so would a hot air gun suffice or should I get a blowtorch?
The last post was made 11 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.3 - MySQL Queries: 14 - Page Size: 27.57 Kb
