First full week as a biker
Kamikaze Bob
PostPosted: 14:32 - 31 Oct 2014    Post subject: First full week as a biker Reply with quote
After a few hiccups last week, I've ridden in and out of work every day this week. Had a few goes at filtering on the motorway, some back roads, and a few idiots who don't look out for bikes. Or do look out and purposely try to block me!
A few small things I've noticed in the past week on the VFR:
    Filtering is tiring when doing it a lot - it took longer getting home last night on the motorway than my usual back road route, mostly due to almost constant bumper-to-bumper traffic. I took it easy but my arms and upper body were sore last night, although I may be tightening up a little as I'm not used to it yet
    The slightly bent-over riding position isn't killing me as much as I thought (I have a very old back injury which I was expecting to kick in) but the base of my neck hurts after a while. Could that be due to the backpack I'm wearing?
    The inner gloves I bought are already scrapped. Put them on yesterday on the way in as my fingers were almost numb earlier this week, [edit - numb from cold, not vibration or anything, should have said] they just caused me to lose feeling on the throttle. Couple that with more end-to-end traffic and loads of filtering and my right arm was stiff yesterday morning
Also, overall I feel more tired than usual from riding, but I expect that will be from more constant riding, rather than just lessons for a few hours every week or two.
One thing I do want to ask - how do most people handle riding in the pitch black on the back roads? I drove the A71 from Blackburn to Wishaw once a week after work all summer and loved it. Done it Wednesday night and got to my destination with slightly brown underwear! I kept the speed up but not being able to see the road in front of me was a bit daunting to say the least! Tried using the pass light to give me a snapshot of the road but is it alright to keep doing that?
Oh, and the Fi light was flickering last night on the way home. Some research and subsequent testing on the ride in this morning tells me the earth box is probably fecked, so that's my weekend sorted! The missus will have a fit when she finds out....
2001 Honda VFR800fi
barrkel
PostPosted: 15:11 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
Most likely because of the weight of your helmet. Try a lighter one, if you can afford it. Or after a while, your neck muscles should adapt.
my fingers were almost numb earlier this week, they just caused me to lose feeling on the throttle.
Do you have stock bar ends installed, or after market? What revs do you cruise at? I don't get enough vibes from my VFR at any of my cruising revs to get significant numbness, though I could potentially see it happening if I hung around just before VTEC kicked in.
Make sure your lights are properly directed at the road. The VFR has excellent stock headlights, better than I've experienced on any other bike without additional lights.
Other than that, because lights don't follow the bike around a corner, you need to take it easy going around them - you won't be able to see very far ahead. So don't go too fast unless it's very straight.
If there's nobody in front of you, use your full brights. The VFR (at least VTEC version) uses 4 single filament H7 bulbs, so there should be no risk of overheating if using the pass light for extended periods either, but the dipped / full switch is generally less faff.
If it used H4, then the pass light is lighting up two filaments in a bulb that normally only has one or the other. My scooter is like that, extended use of the pass light will cause it to overheat after a while.
Kamikaze Bob
PostPosted: 15:46 - 31 Oct 2014    Post subject: Reply with quote
Cheers barrkel - I should have made it clearer tho, the numb fingers were from the cold, nothing to do with vibration or anything. Tried the pair of inner gloves as insulation but lost the feel of the throttle. For my half-hour commute the cold fingers at the end were easier to live with.
Have told the missus I want to get the Shark Evoline helmet, as a flip-front would help with my specs and I like a bit of wind in my face at slower speeds. Tried it on at my local J&S at the weekend and I really like it, but don't have £320 to spend just now. Will probably get some gift vouchers at Xmas but will still have to put a fair whack to it myself.
Is there anyone in the Motherwell area who would be able to help out with the earth box at all? I'd be able to find my way, but as it's my first bike I don't want to fuck it up trying to get to it.
2001 Honda VFR800fi
c_dug
PostPosted: 16:09 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
Slowly!
I'm not a slow rider by any means, but if you can't see far enough ahead to stop if, say, a deer were in the road, then you need to slow down until you could.
Full beams are your friend though, that's what they're there for after all. Just dip them when cars come the other way. Also, might sound obvious but avoid looking at the car lights when they are coming towards you to prevent dazzle.
chickenstrip
PostPosted: 16:49 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
    The inner gloves I bought are already scrapped. Put them on yesterday on the way in as my fingers were almost numb earlier this week, they just caused me to lose feeling on the throttle. Couple that with more end-to-end traffic and loads of filtering and my right arm was stiff yesterday morning
I wouldn't have thought a back pack would help, although many seem to use them without problems. But I wouldn't put anything hard/heavy in one, cos if you come off, risk of further injury.
Back lanes at night? Weeeeelll..... https://www.bikechatforums.com/viewtopic.php?t=296567
I had a break from riding last winter for 2 months. When I got going again in the spring, I found it very tiring, aches and pains after long rides. Kept going with it and soon got used to it again.
My background: old and broken! Laughing (48, with many previous injuries).
trevor saxe-coburg-gotha
PostPosted: 19:53 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
Smart money's on this - and nice one for recognising it. Heavy traffic on motorways can definitely be fatiguing, ime. Just try to stay physically relaxed, but always mentally very alert. Get into some rad Cartesian dualism. Wink
Bungee your pack on next time, and then see how that feels. Iirc the vfr has useful points at which to hook stuff on.
Again, I'd say the numbness is down to being physically tense. A more relaxed grip means better circulation, and loads more 'feel'. Probably the arm thing is tenseness too.
Just keep it on high beam until seeing oncoming traffic. *shrug*
iooi
PostPosted: 19:56 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
Kamikaze Bob wrote:
The inner gloves I bought are already scrapped. Put them on yesterday on the way in as my fingers were almost numb earlier this week, they just caused me to lose feeling on the throttle. .
Make sure that any inners DO NOT make your gloves TOO TIGHT.
You need to have a air gap for them to be effective.
So if you want to wear inner glove's then you will need a bigger pair of gloves Thumbs Up
TBH. We have not had anything like cold weather yet. Cold is reserved for when its gets to - 0 temps.
Northern Monkey
PostPosted: 20:03 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
If the gloves squeeze your fingers, then the circulation is reduced, making your hands colder. Look for silk undergloves often used for skiing
Alpha-9
PostPosted: 20:09 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
Headlights, generally
Fzr-600 1999
PostPosted: 20:41 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
https://i58.tinypic.com/2rxdx5e.png
If you can't see, slow down. Man Points are not actually redeemable for new spines.
PostPosted: 20:53 - 31 Oct 2014    Post subject: Re: First full week as a biker Reply with quote
Yep and take it easy
'never drive so fast you cannot safely stop in the distance you can see to be clear' and all that
Dont know what your headlights are like but if you cant see very well upgrade them.
I followed my lad up a country road on his scoot one night
and on a whim turned off the headlights on my beemer( quiet road)
His brake lights came on immediately.
As I suspected, he couldnt see much by the scoot lights, was riding by mine and
although he wanted to go on to the midlands, I advised him to turn back.
Kamikaze Bob
PostPosted: 00:35 - 01 Nov 2014    Post subject: Reply with quote
Thanks for the replies guys. Should have edited the initial post after barrkel's post - the numbness the other day was from cold, not vibration or anything. Tried the gloves for warmth but all they did was lose feeling on the throttle and didn't help with the cold much anyways.
Took off from work an hour early today and rode the same A71 stretch in the daylight and it was much easier. Except for the massive side-wind threatening to blow me into oncoming traffic! Just need to slow it down in the dark as suggested, take it easier.
Did manage to shake a nut loose today, resulting in my exhaust hitting the ground. Got it back on well enough to get to my local garage and get it sorted, but that was something I didn't expect. Won't be using the backpack much longer, have a tankbag coming - free gift for a subscription to Ride - and it should be big enough to cover the work stuff.
Have also decided, for times' sake as much as fun, to keep taking my back road route rather than the motorway. At least I have the chance to overtake on most of it instead of picking my way through traffic, and I'm sure my average speed is higher. Should also help me loosen up a bit if I'm not trying to constantly watch my flanks for idiots in Audis or vans, and at least I know that filtering isn't as bad as some make out and I should be fine if I ever have to do it again.
2001 Honda VFR800fi
chickenstrip
PostPosted: 09:49 - 01 Nov 2014    Post subject: Reply with quote
Cold hands; handlebar muffs (very effective but look awful) or heated grips - bliss!
And of course there are heated gloves available, tho' personally I CBA with wires hanging out/connecting up every time etc. So plenty of methods to try.
Kamikaze Bob
PostPosted: 14:34 - 01 Nov 2014    Post subject: Reply with quote
Well there are heated grips on the bike, just need to get a controller and wire them up. But want to get the Fi light sorted first, no point getting the hands heated if the bike's gonna break down.
2001 Honda VFR800fi
rideslikean00...
PostPosted: 15:15 - 01 Nov 2014    Post subject: Reply with quote
Good choice. Motorways are boring, unless it's a long clear stretch and you want to see how fast you can go in a straight line. Twisties on a set of good backroads with lower traffic are much more fun, even in the dark when you have to keep your speed down.
For me, and some other riders on here I've been told, the motorway is for utility only. It's kind of a dull way to pile on the miles. I tend to avoid them unless they're faster than going through, say, city roads (come out on the junction closest to where my destination is) or the weather is so awful that it's safer to filter on the motorway than try my hand on damp, dark country roads behind people too shit scared to get above 30 in their cages.
Don't even stop looking out for idiots on the road, they're always there. My current main nemesis are Qashqai drivers - they're bad even for faux-by-faux numpties.
Filtering isn't bad, it just requires a lot of concentration. People will try to block you and often you have about a second to contemplate coming to a stop or seriously reducing speed, or two HGVs might be too close together and you'll need to take some evasive action. My personal rule is, never filter over 40mph. Not worth the risk, you're not leaving yourself the reaction time or - crucially - leaving the numpties in cages their slower reaction time either. Pick and choose your moments to pass. As you learn the roads and improve your road sense on a bike you'll know instinctively which areas are suitable for filtering, and which you can push on further and flat out overtake other vehicles.
Previous/Current Bikes
2013 Yamaha YBR-125ED -> 1997 Yamaha YZF-1000R Thunderace -> 2009 Yamaha XJ-6 Diversion -> 2007 Yamaha FZ6 Fazer S2
The last post was made 11 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 104.86 Kb
