| zzrsean |
 zzrsean L Plate Warrior
| Copycat73 |
 Copycat73 World Chat Champion
 Posted: 20:49 - 08 Nov 2014 Post subject: |
I`m thinkin air getting sucked in via the carb inlet rubbers.. or manifold inlet rubbers..
didn`t these have some clever heater system on the carbs to stop icing up .. pipe ran from the coolant system  ____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
| lozzypop1 |
 lozzypop1 Certified MILF!
 Posted: 22:36 - 08 Nov 2014 Post subject: |
Could it be the pilot air screws were set up by following the manual (which will say how many turns out) and not by use of a gas tester. Of course, the manual won't take into account the bike being 15 years old or carb wear.
If they are set up using a gas tester, a lot of the problems may disappear.
Many kawasakis idling with the choke on will run at between 3-4k rpm. I believe this is a normal thing for them.  ____________________ Funny, I used to hate being spanked as a child!
Tell me and I'll forget; show me and I may remember; involve me and I'll understand. |
| Fizzer Thou |
 Posted: 11:55 - 10 Nov 2014 Post subject: |
Have the valve clearances been checked within the the bikes mileage?
They are easy to check and if the shop was any good then that would be easily done.Also,with the engine hot,plugs out and perform a compression test.If low then this would suggest that the valves are not seating,so losing compression.
With the engine cold the clearances can be checked and because of the cam follower arrangement,they can be pushed to one side so as to access the clearance adjusting shims.
The biggest effort is removing the bodywork to access the cam cover But at least you do not need to remove the cams so as to adjust the shims,like you do on some engines  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| 1198 |
 1198 World Chat Champion
| Supermoto_Fan |
 Supermoto_Fan World Chat Champion
 Posted: 22:09 - 10 Nov 2014 Post subject: |
After spending 2 weeks taking my bike apart and trying to sort a very similar problem with a few bonus symptoms, I simply as a last resort, unplugged each of the 2 carb heaters one at a time and it made a significant difference after the first, once both were disconnected it was like a different bike. Absolutely fine.
Hard to believe something so minor (and that many people say didn't need to be fitted to the bike from the factory), can cause such major problems
Still need to get a multi meter to confirm resistance readings but sure it's those.
Just check  ____________________ Yamaha MT-09 - Triple powerrrr |
| mentalboy |
 mentalboy World Chat Champion
The last post was made 11 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
