Aprilia rs125 clutch drag issue ((Solved))
gtchtc07
PostPosted: 20:41 - 24 Nov 2014    Post subject: Aprilia rs125 clutch drag issue ((Solved)) Reply with quote
many people including me have been having an
Issue with the clutch slightly engaging when stopped
In traffic and at lights,,, e.g. When in 1st gear and pull
Clutch in the bike tries to pull forward,, after weeks of adjusting
The clutch again and again I decided a rebuild is necessary although running a brand new clutch,, the problem lies in the friction plates alignment, when you look at the clutch from the engine side with the 6 8mm nuts holding the clutch springs, your top friction plate should be sitting in the cut out groove at the top next to the other slot with all other friction plates situated, if all friction plates are situated in the same slot as mine were Sad your clutch will drag
Hope this helps you all, will add a Haynes photo for illustration
The last post was made 11 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 27.59 Kb
