| Tom928 |
 Tom928 L Plate Warrior
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:35 - 27 Nov 2014 Post subject: |
just because some "mech" changed your clutch, doesn't mean he did it right. He probably didn't change the springs. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 05:59 - 27 Nov 2014 Post subject: |
The wrong oil can shag the clutches on these. The Hydraulic tappets don't like the wrong oil much ether; so make sure that it's the right stuff.
Symptoms sound like it's clutch slip; ish.. but when mechanic says they have 'done the clutch' that could mean almost anything from adjusting the cable to replacing the plates....
Small niggle on the CBX750 engine is that it has a 'weird' castle nut on the clutch.. finally got round to swapping the plates on mine that have been in the ready spares box for three years this summer; that nut is nie on impossible to get off without the 'official' Honda tool, which is something like £50 at DSS, and on 'special order', and not to be found on e-bay. ended up buying, think it was a deep 32mm impact socket, and the painstakingly grinding out the castle profile on the face to fit the nut with a chuffing dremmel!
This suggests that there is MORE than a small chance that your mechanic, lacking the Honda special tool, and finding it rather ore than difficult to try chisel the thing off, HASN'T done any more than take the clutch cover off, look at it; the put t back together, bung in some thicker oil and wind the cable adjuster off a bit ad give it you back!
From memory, I think there are seven friction plates, two their ones on the ends and five thicker in the middle; priced according to CSML at approx £10-£15 each which implies that a full pack would be about £70, Clutch springs are approx £4 and I OUGHT to remember if there were 4 or 6 but I cant! Think there are 6, which would bring parts total up near £100 with a gasket; With the castle socket? Probably about an hour's labour; it's NOT a big job.
So, I'd look at the invoice; if you weren't charged £150-£200, good bet that clutch ENT been replaced. If you WERE charged that sort of money, look at the receipt, see if they have listed parts used, and hours of labour.. cos my bet is mechanic hasn't got past that bludy castle nut..... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Tom928 |
| stinkwheel |
 Posted: 10:15 - 27 Nov 2014 Post subject: |
I can think of only three possible causes of the revs increasing but the speed remaining the same on a motorcycle with a conventional manual gearbox.
1) Clutch slip.
2) Rear wheel spinning up.
3) Teeth totally worn off front sprocket.
I would hope you'd have noticed items 2 and 3. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 10:27 - 27 Nov 2014 Post subject: |
| Tom928 wrote: | So I'm guessing normally a Motorbike which Revs shoot up is caused by a Worn clutch - can't be anything else? |
Ever watched a Motocross? Or more aptly 'heard' one?
Revs is shooting up and down all the time... every time the back wheel stops touching the ground or loosing its grip on it.
My VF1000 would do it quite readily if I was a bit brutal with the throttle, or the road was bumpy, or wet...
750-Retro? Err... its shear mass does a fairly good job of keeping the wheels on the ground and in touch with tarmac; only time I have had it spin up has been when I had a REALLY crappy set of tyres on it and shagged dampers, or been pissing about on grass.
So yeah, there are other possible causes...
Has it still got the OE showa fake 'piggy-back' shocks on it? What tyres are you running? How old? What pressure?
Those Showa's were a bit soggy when new and wont have improved with age; when I got mine, it came with budget R&R's on it, £50 springs, and that was about all they were; I put it down to them being old ad knackered ad got another set; they lasted barely a year.. got it through a MOT but that was about all they were good for... so, bit the bullet and coughed up for Hagons, that have been on it ever since.... aprox seven or eight years.. might be something to look at. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| doggone |
 doggone World Chat Champion
The last post was made 11 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
