Kawasaki GT550 Tank Removal
tstwebdesign
PostPosted: 14:57 - 04 Dec 2014    Post subject: Kawasaki GT550 Tank Removal Reply with quote
Hey guys,
I was wondering how difficult it is to remove the tank from a Kawasaki GT550 for painting.
I'm not sure if it's a straight forward removal as you would normally do with a gravity fed carb or whether there are other complications such as the fuel gauge etc.
Thanks in advance.
Honda CG 125 & Kawasaki GT550
map
Mr Calendar
PostPosted: 15:07 - 04 Dec 2014    Post subject: Reply with quote
Easy.
Take seat off.
Take out bolt at the seat end.
Lift up at the back and remove the pipes for the fuel and the electric connector for the fuel gauge. It's a vacuum fed so should not leak fuel (iirc tap only has on, reserve and prime).
Paddy Blake
PostPosted: 16:06 - 04 Dec 2014    Post subject: Reply with quote
Don't turn the tap to prime,I think that bypasses the vacuum.
Paddy Blake
PostPosted: 16:07 - 04 Dec 2014    Post subject: Reply with quote
tstwebdesign
PostPosted: 16:42 - 04 Dec 2014    Post subject: Reply with quote
Thanks very much for your help!
What would I turn the tap to before removing the fuel line? It his on, reserve and prime.
map
Mr Calendar
PostPosted: 16:46 - 04 Dec 2014    Post subject: Reply with quote
tstwebdesign wrote:
...What would I turn the tap to before removing the fuel line? It his on, reserve and prime.
Leave it set to on. Never had a problem.
You may find two rubber pipes. Undo the thicker one after the fuel tap. IIRC the thinner one is for the vacuum feed. Then there's a white electric connector for the fuel gauge.
RhynoCZ
PostPosted: 17:32 - 04 Dec 2014    Post subject: Reply with quote
The thicker one is fuel, the thinner is the vacuum. There's no need to think about it really. If the fuel tap works alright, then leaving it on ON will shut the fuel, so just take the hoses off as you feel it, there's no prescribed order. Thumbs Up
At least the GPz was like that, and it's the same thing as your GT, if I'm correct.
The last post was made 11 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.43 - MySQL Queries: 14 - Page Size: 53.67 Kb
