Jetting DRZ 400 - 424cc Hot Rods 4mm Stroker Crank
sumo_blake
PostPosted: 19:42 - 27 Dec 2014    Post subject: Jetting DRZ 400 - 424cc Hot Rods 4mm Stroker Crank Reply with quote
Hello to all, to all Hello!
After searching galore on ThumperTalk and any other forums I could find.
I still remain unknowingly to the correct Jetting specs after installing the
DRZ Hot Rods 4mm Stroker Crank alone. Thus bringing the dr zed to a
424cc.
I have the standard size carb and the standard piston. Having this all
can
still work with the crank kit installed, but alas like I said, I would just like
to know the correct/ best jetting kit I need to follow this upgrade!
This post is been put up to start a discussion or any advice on the
matter (which I fully and truly appreciate)!
Any questions about my bike I can answer if it helps
DRZ 400 SM 2007 K7
Thanks in advance ! ! !
sumo_blake
PostPosted: 19:43 - 27 Dec 2014    Post subject: Reply with quote
If the answer to this riddle is found out
I'm sure it will help many others and myself, alot !
Thanks
The last post was made 11 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.83 - MySQL Queries: 14 - Page Size: 31.77 Kb
