A xr250r, an unidentifiable hole...
RhynoCZ
PostPosted: 18:46 - 26 Dec 2014    Post subject: A xr250r, an unidentifiable hole... Reply with quote
Hello, lads and lasses, do you happen to know, what's this hole for? I mean the rectangular one between the two intake channels. I'm not sure what year the bike is, the owner says '89, but I think it's '85. Thanks,
https://i.imgur.com/ucBL83D.jpg
Nemo
PostPosted: 18:58 - 26 Dec 2014    Post subject: Reply with quote
Probably coolant, to prevent carb icing.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
PostPosted: 19:14 - 26 Dec 2014    Post subject: Reply with quote
Casting feature IMO.
RhynoCZ
PostPosted: 19:18 - 26 Dec 2014    Post subject: Reply with quote
The hole is 7+cm deep. Thinking
Fizzer Thou
PostPosted: 10:17 - 27 Dec 2014    Post subject: Reply with quote
As Pete said,it is just a casting mark.
As it is air cooled there is no water jacket Thumbs Up
It is more likely the '84-'85 model,as that cylinder head is for a twin carb version,as against the '89 model which was single carb
https://www.cmsnl.com/honda-xr250r-1989-belgium_model6767/partslist/E__0201.html#results
https://www.cmsnl.com/honda-xr250r-1984-usa_model876/partslist/E++02.html#results
Always have a 'Plan B'
Snod Blatter
PostPosted: 09:56 - 29 Dec 2014    Post subject: Reply with quote
The early dual carb heads have a reed valve over that hole (part of the rubber inlet manifold) which allows the cool intake charge to be shared from the slow running carb to both inlet valves, so it goes from left to right. This was abandoned somewhere around '85-'86 as it didn't seem necessary for reliability but presumably Honda couldn't be bothered changing the casting Thumbs Up
Second picture along the bottom hopefully explains it:
https://i.imgur.com/rF4EeeQ.jpg
bikenut
PostPosted: 12:03 - 30 Dec 2014    Post subject: Reply with quote
nice article.......you may have problems looming with all that sealer everywhere......blocked oil holes ??
nuts about bikes
The last post was made 11 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.26 - MySQL Queries: 14 - Page Size: 52.88 Kb
