| Jonny491 |
 Jonny491 Borekit Bruiser
| Minty |
 Minty World Chat Champion
| grr666 |
 grr666 Super Spammer
 Posted: 14:35 - 02 Jan 2015 Post subject: |
Does it also charge via HDMI? There's a mini HDMI socket there but you may
need to source a cable. I got one from ebay myself for 1.99 delivered.
I'll have a go with mine later and report back ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| doggone |
 doggone World Chat Champion
| Musketeer |
 Musketeer World Chat Champion
| -Matt- |
 -Matt- World Chat Champion
 Posted: 15:46 - 02 Jan 2015 Post subject: |
If its only the USB connection point thats damaged this might be a cheap get-around fix.
External charger (and a spare battery) for under a tenner.
Imagine that will still leaves you with the problem of getting the videos off the camera, but if you get a cheap USB card reader like this you should be able to get files off it easily.
Not a fix admittedly and will take a few seconds to remove the battery/card each time, but I doubt getting it properly fixed is going to cost around a tenner  |
| Beehive Bedlam |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
 Beehive Bedlam World Chat Champion
| barrkel |
 barrkel World Chat Champion
 Posted: 17:28 - 02 Jan 2015 Post subject: |
I have two batteries, a charger and a USB microSD card reader. One battery is always charging, when the camera runs out of battery I just swap over. I never plug mine in via USB, unless I'm touring and I need to charge two batteries simultaneously overnight.
I've had bad luck with mini-USB connectors, all too often they've stopped working on various devices. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Iain. |
 Iain. Could Be A Chat Bot
| Beehive Bedlam |
| Irn-Bru |
 Irn-Bru World Chat Champion
 Posted: 18:59 - 02 Jan 2015 Post subject: |
Contact Drift support they are quite good, I have had to loads in the past  ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| -Matt- |
| MC |
 MC Banned
| Jonny491 |
| Albigularis |
 Albigularis World Chat Champion
| grr666 |
 Posted: 12:53 - 03 Jan 2015 Post subject: |
I'm pretty happy with mine too.
Seems quite robust to me as well.
My screen/bodywork mount arrived today so I may go out in my S3
for a play later. Too wet for video shenanigans on a bike where I am today. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| Musketeer |
| grr666 |
| Albigularis |
 Posted: 14:47 - 03 Jan 2015 Post subject: |
| mJZ wrote: | As the thread shifted towards "What do you think about your Drift?" I will say I don't like my Drift Ghost.
-It often freezes and the only way to make it work is removing the battery for a moment.
-Battery life is only good when the battery is new, then it's not that great.
-Video quality is OK'ish, GoPro is much better.
-Drift mounts are rubbish, I replaced all the mounts with GoPro ones + adapter.
-A fault developed with my battery hatch, when asked about parts availability (dealers don't have them) my email was simply ignored. There are no other parts available than lenses, batteries and mounts so I'm pretty sure OP that you won't find anything useful from Drift website to repair your USB port. |
With the freezing, is it just total lock up, or is there an error that comes up? I get a 'slow card' error every so often, about once a month.
Haven't had an issue with battery life, are you recording on High Bitrate perhaps?
GoPro 3s look about the same as the Ghost S with the Ghost S edging the win, the 4 is a bit better than the Ghost S.
What's wrong with the mounts? I've got the curved one on my helmet and I tried to take it off when changing helmet and nearly broke the old helmet in the process... That 3M stuff is crazy. To be fair enough I did clean both my helmets with IPA to get them clean as can be. ____________________ Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa |
| Beehive Bedlam |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| Irn-Bru |
| Musketeer |
 Posted: 18:43 - 03 Jan 2015 Post subject: |
| Albigularis wrote: |
With the freezing, is it just total lock up, or is there an error that comes up? I get a 'slow card' error every so often, about once a month. |
The camera becomes unresponsive, the only way to fix it it to take the battery out and put it back in. I've never had card errors though - I used only 32GB 10-rated one, so that particular card was causing no problems.
Haven't had an issue with battery life, are you recording on High Bitrate perhaps? |
I record 1080p at 30fps. I've had 3 batteries and same happened to them. At first I could get about 2.5 hours out of them if recorded in one go. Then that decreased to much below 2 hours after a while. Also Drift Ghost drains the battery when not used. The worse battery age the more of that effect you experience. If I leave one of my fully charged batteries inside the camera for one night (camera switched off) then in the morning out of three bars I get 2 if I'm lucky, but more likely 1. So basically it needs to get charged again. I made keeping batteries outside the camera a habit. But that problem exists.
GoPro 3s look about the same as the Ghost S with the Ghost S edging the win, the 4 is a bit better than the Ghost S. |
Did you do the tests by yourself? I can tell the footage from Drift is quite disappointing - it's got good vibrant colours, but it lacks sharpness. I've seen some GoPro footage and it looked better. I cannot say about Drift Ghost S because I haven't tested one.
What's wrong with the mounts? I've got the curved one on my helmet and I tried to take it off when changing helmet and nearly broke the old helmet in the process... That 3M stuff is crazy. To be fair enough I did clean both my helmets with IPA to get them clean as can be. |
Drift mounts with exception of helmet mount are all rubbish. I've tested them all on the motorcycle. Too much play and shaky videos. Also not great variety. And there are really no decent mounts to attach your camera for track days. The main issue is the bit attached to camera that slides into your mounts. There is just too much play in those - any vibration kills your footage. No that much vibration on your head so it doesn't work too bad there and the mount is sufficient.
I still use Drift as helmet camera. Don't get me wrong, it does the job. I bought it so I use it. I'm a bit worried that the footage may not get recorded if I crash. I crashed in Cadwell Park and all I got was a corrupted file, which I fixed eventually but all that was recorded was everything until about 3 seconds before the crash. So I'm worried it can happen again. ____________________ Current Bike: Yamaha XSR900 Previous bikes: Honda CBR1000RR Fireblade, Kawasaki ZX-6R Ninja, Aprilia RS125 2-stroke
| gbrand42 |
 gbrand42 Could Be A Chat Bot
| DB1965 |
 DB1965 L Plate Warrior
 Posted: 19:03 - 03 Jan 2015 Post subject: |
I have the hd ghost S had the same problems with locking up and card freezing so i reformated all my cards on my pc 64 gb mircro sd;s this sorted the locking problem and the card issues for some reason the cards if you format them via the actual camera unit cause problems saw this fix on a techy site and has worked well for me. so make a point of reformating on the pc whenever copy over vids now with a monthly factory reset on the actual unit as well
the batteries brought a charger i can charge via a USB socket on the bike. This Unit comes with a couple of batteries not Drift Pantone for 23 quid comes with USB, Cig & plug leads for the charger unit https://www.amazon.co.uk/Bundle-Charger-Battery-FX-DC02-1800mah/dp/B00GXEIQOO/ref=sr_1_3?ie=UTF8&qid=1420308096&sr=8-3&keywords=drift+batteries 1/3 the price of drift replacement batteries and good charger unit all ce marked ect, one of the benifits of having a Funk with a twin usb socket installed in it  ____________________ Reborn Rider (aka OFB;))
Current ride Honda NC750XAE
The last post was made 11 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
