Rs 125 cilinder wall has scratches
Runeazn
PostPosted: 17:00 - 27 Dec 2014    Post subject: Rs 125 cilinder wall has scratches Reply with quote
I recently bought a rs 125. Wanted to check up on the engine state, so I went to a motor shop to let them look at my cylinder and they suggested to get it replated. Though the motorcycle ran fine, I only opened the cylinder to check the state of the piston. In first case I wanted them to polish the wall till they said they wouldn't because it was damaged too much. When I feel it with my finger they feel like really thin grooves. Deeper then the honing grooved but I think just as deep as 1200 grit sanding paper? These grooves probably happened because of overheating, the coolant hose was teared. I'll place some pictures.
Also I'm ready to pay for a new cylinder, though it's cheaper not to, but an whole engine rebuild is worse. So I'm trying to get a good judgement. The kits I'm looking at are mitaka or italkit. I'm not looking at replating because it's even more expensive than a mitaka top end kit.
Boxing
PostPosted: 17:02 - 27 Dec 2014    Post subject: Reply with quote
The shop is mechanics, they know best. Get it re-lined and stop being cheap.
Runeazn
PostPosted: 17:26 - 27 Dec 2014    Post subject: Reply with quote
Fair enough but I'm not letting them replate it. They charge 200pounds here. 30 pounds more than buying a new top end mitaka kit with cilinder.
Copycat73
PostPosted: 17:43 - 27 Dec 2014    Post subject: Reply with quote
so all shop mechanics are competent and would never tout for unnecessary work.... Rolling Eyes
pics of offendin bore & piston would be of interest. Thumbs Up
caveat emptor
robertw95
PostPosted: 17:55 - 27 Dec 2014    Post subject: Reply with quote
Im guessing the rs cylinders are nikasil plated and not steel lined then? Re bore out the question
07 Dt125r, sv650s k8, zx6rr 04
Copycat73
PostPosted: 18:49 - 27 Dec 2014    Post subject: Reply with quote
you are quite right to question this ...
which is why I asked for jpg.s
particularly from above said cylinder head.
caveat emptor
Runeazn
PostPosted: 18:50 - 27 Dec 2014    Post subject: Reply with quote
Hence I was talking about replating. Resleeving a cast iron sleeve seems a option also but I'm not sure if its better or worse.
Here are the promised pictures(right click-> view image for whole picture) :
https://i.imgur.com/X86pdEQ.jpg
https://i.imgur.com/C3fhjIh.jpg
https://i.imgur.com/lVmWN0h.jpg
https://i.imgur.com/trqc37l.jpg
https://i.imgur.com/up49eXi.jpg
https://i.imgur.com/HRV9Lkw.jpg
Copycat73
PostPosted: 19:10 - 27 Dec 2014    Post subject: Reply with quote
To hone the Aprilia RS 125 cylinder you need special diamond tooling to cut thorough the tough nikasil coating,for this we use our sunnun precision honing machine
(£40.80 Including VAT at 20%)
then you got pistons, rings .. gudgeon pin c clips, gaskets...
wot u get in that kit like ?
although it don`t look fantastic is you sure its fcuked...
did you not compression test it before strippin ?
this may be of interest
https://www.pjme.co.uk/
caveat emptor
robertw95
PostPosted: 19:40 - 27 Dec 2014    Post subject: Reply with quote
If its steel plated i'd regard a re bore as standard 2 stroke maintenance certainly is on the dts, send it to an engineering company such as pjme which is highly recommended and they supply correct over size piston/rings for the cylinder
If nikasil from my limited knowledge i thought the only option is re plating?
Runeazn
PostPosted: 19:56 - 27 Dec 2014    Post subject: Reply with quote
if you'd pick it up in the netherlands...
The shop here said they didnt want to take the responsbility of trying to fix it.
Also no-one can hone it in Netherland, so replating is the onliest option. Replating is 200 pounds here so it's also a bad option
compression was 100psi hence I wanted to rebuild, till I saw this and let a mechanic look at it.
robertw95
PostPosted: 20:08 - 27 Dec 2014    Post subject: Reply with quote
I dont think thats an unreasonable price mate, rs125s are known high maintenance bikes if not properly looked after and often bought by 17 years who thrash the bike
Runeazn
PostPosted: 20:16 - 27 Dec 2014    Post subject: Reply with quote
Once again I live in Netherlands where this bike can be driven under the A1 motorcycle license >18 year olds, though doesnt mean it doesnt get thrashed.
If honing this is possible then i'd rather do that, else i'd just buy that mitaka kit for 170 pounds on pjme.
Well it does look like it hasn't been thrashed that hard though, the whole engine has new gaskets, atleast it doesnt look standard. It might even had a full engine rebuild somewhere, as germans are decent in keeping their motorcycle running, not to forget the yearly vehicle checkup they need to do.
robertw95
PostPosted: 20:19 - 27 Dec 2014    Post subject: Reply with quote
If it is nikasil then re honing isnt possible im pretty sure, what mileage is the bike on? You sure this piston kit includes a cylinder seems strange to me?
Runeazn
PostPosted: 20:23 - 27 Dec 2014    Post subject: Reply with quote
https://www.pjme.co.uk/acatalog/Aprilia_RS125_Engine_Top_End_.html
also see my edit about the yearly check-up
robertw95
PostPosted: 20:28 - 27 Dec 2014    Post subject: Reply with quote
Ok so your doing a top end rebuild that kit has piston rings etc and are known reliable rebuild my dt twice using there kits no problems.
The cylinder hower needs replated after that damage to get rid of those scores, had a look on pjme and a re sleeve says £103 + vat I would get in contact and confirm this is right for your model of bike so under 200 for a complete new top end seems decent to me
I'd also be checking the spark plug to see how the engine is running possible overheating caused that or lack of oil
Runeazn
PostPosted: 20:36 - 27 Dec 2014    Post subject: Reply with quote
First thing was a new plug.
I didnt even drive it for more than 300m, before I decided stripping the motor. Why does that dude not sure if hes from pjme suggest honing the cilinder?
I really have no clue what to do, also resleeving costs 200 pound here. in the netherlands.
might as well use that kit,also you need to scroll down to the mitaka cylinder kit.
robertw95
PostPosted: 20:58 - 27 Dec 2014    Post subject: Reply with quote
Im only guessing here never dealt with nikasil bores before but if its iron/steel lined and scored but you cant feel the marks you can re hone the cylinder removing the marks this may be possible
Just me but id prefer to have the standard cylinder re plated by pjme just for piece of mind and fit a new piston rings etc then you know the engine hasnt been thrashed.
I had considered one of these bikes before but looked into it before buying these bikes dont make 33bhp as many claim probably closer to 28ish which is impressive for a 125 but it will require maintenance to keep it in good working order
Runeazn
PostPosted: 21:09 - 27 Dec 2014    Post subject: Reply with quote
replating by them is not a option except if they collect it here in the Netherlands.
Another option is to send my cylinder to 2radsausenthaler en they will send me one of their replated cylinders. Just dont like the fact I'm getting some elses cylinder instead of my own.
PostPosted: 19:28 - 28 Dec 2014    Post subject: Reply with quote
That barrel looks OK, except above the exhaust port which looks a mess.
You can get barrels replated. Think there are 2 people in the UK who do the actual replating. Cost is around £100 + vat (but then you need a piston, gaskets, rings, etc as well). Not sure whether they will post to the Netherlands, but posting to them should be easy enough.
A cast liner can also be fitted, although personally I am not keen on this; only experience was one being supplied by Aprilia UK under warranty which was a mess. Others have had no problems with them. Cost is similar to replating although in future you can then rebore them.
The Mitaka kit is a possibility. Some people have issues with them (think PJME supply them with alternative rings), and based on reputation you might lose a little performance.
Runeazn
PostPosted: 12:16 - 29 Dec 2014    Post subject: Reply with quote
Tried to call them today for replating but I guess they are closed today. Kinda want to repair this barrel without replating, and buy mitaka kit as substitute for a while.
Is repair to this barrel possible? Or is it a no go?
PostPosted: 23:51 - 29 Dec 2014    Post subject: Reply with quote
Suspect they might be closed until after the new year.
I would suspect that barrel can easily be repaired, but a Mitaka kit to keep the bike running for now might be a simple solution
Runeazn
PostPosted: 00:10 - 30 Dec 2014    Post subject: Reply with quote
I tried some 4000 grit sand paper using it dry. Does seem to remove a little but im scared of sanding it too much. Maybe going to try 6000/ 12000 grit sander paper next. Still not too sure if this is the right method.
PostPosted: 00:24 - 30 Dec 2014    Post subject: Reply with quote
The plating on the barrel is very hard but very thin. If you wear through the plating then the barrel will be wrecked and replating / fitting a liner will be the only solution. From the pics I can't tell whether above the exhaust port the plating is damaged or whether that is just the remains of a piston smeared on top of the plating
stevo as b4
PostPosted: 00:31 - 30 Dec 2014    Post subject: Reply with quote
If a plated bore doesn't suffer a seizure or the plating flakes off, I was always under the impression that you can keep re-using them and you never hone or sand the bore, just check the dimensions before fitting a new piston kit every 8000miles?
I would like to think that a good plated bore would last 2-3piston and ring changes without wearing the plating out?
I certainly would not choose to fit a liner to a high specific output motor that has an original plated bore.
I'm soon going to put the KMX125 on a dyno, but I'm not expecting much as it was re-build with a steel liner which may or may not reduce performance depending on how well it was fitted and how well it conducts the heat away?
Runeazn
PostPosted: 01:06 - 30 Dec 2014    Post subject: Reply with quote
I have no idea either... I looked at my piston, it seems it has the same marks on the piston. Either the piston rubbed the cylinder or the other way around. I can feel it's not as smooth as the rest of my cylinder, but it's not like it isn't smooth.
Lets say the piston rubbed the cylinder(best case scenario) How would I remove this melted aluminium(?) As this happened because of overheating
The piston rings are 100% fine and look like new and shiny. It hasn't seized yet since it has been in my ownership.
Well let's say I wear through the plating it needs to be re-plated.
Howver in it's current state it's not useable anyways, so it's a win-win situation right?
The last post was made 11 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.44 - MySQL Queries: 17 - Page Size: 138.52 Kb
