2 stroke pistons
Flywheel
PostPosted: 19:14 - 30 Jul 2004    Post subject: 2 stroke pistons Reply with quote
hi
does the shape and size of the ports in a 2 stroke with reed valve effect the performance cause i recently put a new piston im my honda ns125r but when i got it the ports where different sizes and shapes.I phoned up the company the piston came from, Stan Stephens, and they said it dosnt matter cause its got reed valves.
So after fitting the piston and running it in i found the performance of the bike had droped.It had a slower top speed and slower acceleration.
OH ye the piston that came out was the original honda one cause i looked in the manual at the pics.
kev
I Hump Things
PostPosted: 20:23 - 30 Jul 2004    Post subject: Reply with quote
In a word yes they will affect it.
Take it apart and send the bits back and tell them to send you the right bits.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Skvara
PostPosted: 21:47 - 30 Jul 2004    Post subject: Reply with quote
But if it is new piston you should get it rode. You can't go as a racer with new piston!!!
kev
I Hump Things
PostPosted: 22:12 - 30 Jul 2004    Post subject: Reply with quote
And can we have that in english now. Very Happy
aRe_eSs
PostPosted: 22:52 - 30 Jul 2004    Post subject: Reply with quote
bed it in is what i think was meant?
>> Nova boy in rehab.....
Guest
PostPosted: 00:25 - 31 Jul 2004    Post subject: Reply with quote
As I understand it, reed valves simply close on the compression stroke stopping the mixture being forced back through the carb. The ports in the barrel must match the cut-aways in the piston otherwise they're not working as they should. It would restrict the power as you've found, like blocking off part of the exhaust or inlet (which is what's actually happening)
Flywheel
PostPosted: 17:13 - 31 Jul 2004    Post subject: Reply with quote
Thanks for the help.Im gona get the right piston now.I would have also thought that Stan Stevens would know what they where talking about since they are 2 stroke tunners.
oh ye this is after i ran it in.
cagiva gezzer
PostPosted: 15:36 - 01 Aug 2004    Post subject: Reply with quote
Some people sell pattern pistons that do almost the same job as OE pistons, but because they are manurfactured differently they are of different density and therefore can not be made to the same shape.
No doubt the piston was a weisco or prox one. From my experince with pattern mito pistons, the prox ones have lower side skirts and smaller windows which do not work as well as the OE ones.
Even though the ensine is a reed valve engine, the timing is also controlled be the height of the piston and the shape of the windows.
I've got nothing against stanstephens or the "other main prox dealer", as they have served me well in the past, but stick to OE pistons.
Skvara
PostPosted: 20:07 - 01 Aug 2004    Post subject: Reply with quote
kev:sorry I cannot translate it to better English but if you want I can post it here for you in Czech Smile
kev
I Hump Things
PostPosted: 19:19 - 03 Aug 2004    Post subject: Reply with quote
Sorry mate I just thought you were a chav doing text talk kind of thing.
The last post was made 22 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 14 - Page Size: 62.83 Kb
