Project TTaRt up!
Fladdem
PostPosted: 18:08 - 03 Apr 2015    Post subject: Reply with quote
I gave her a bit of stick last time and had no issues. I may just do the same again. Confused
I took her for a spin round the block last night and it seems to pull quite well, it feels really tight and crisp. The revs are very responsive. It pops a lot on the overrun, so much so flames were coming out the exhaust, I could see this in the daylight, it would look awesome at night. Laughing I don't know if this means it is massively lean or massively rich?
I can't tell much of a difference with the new chain and sprocket combo, I guess I've given it a bit more power and it can pull the new ratio better, it still lifts the front wheel OK in third. Twisted Evil
Fladdem
PostPosted: 12:27 - 04 Apr 2015    Post subject: Reply with quote
She pulls like a champ. Or as best as an air-cooled 250 four stroke will. I kept over-revving her though, I'm used to the rev hungry two stroke now. Embarassed There are no flat spots all the way up to the rev limiter. Yes, I hit the rev limiter with less than 2 miles on the new rings. Twisted Evil Right from the bottom, you can smack the throttle wide open and it just revs up.
She is just running very hot. I pulled the plug and it suggests a bit lean, not a lot but just a tiny bit away from just right, I may go up a size on the pilot and drop the needle clip one position, possibly up again on the main, but I'm not sure If I need to go up more or not, I might just buy the jets and then see if they need to go in or not after adjusting the needle and pilot. Thumbs Up
Fladdem
PostPosted: 12:51 - 11 Apr 2015    Post subject: Reply with quote
Got her in for an MOT today, she passed with only an advisory on the front pads getting slightly low, which I was weighing up changing before test anyway. Now to let the system update, get some tax on her and go for a burn! Twisted Evil
Fladdem
PostPosted: 18:59 - 17 Apr 2015    Post subject: Reply with quote
DEAD Crying or Very sad
/Thread
stevo as b4
PostPosted: 19:05 - 17 Apr 2015    Post subject: Reply with quote
What's happened dude?
Hope your not going to say a dropped valve or something nasty like that?
Fladdem
PostPosted: 19:11 - 17 Apr 2015    Post subject: Reply with quote
Gearbox kersploded on the way home, I ended up stuck in 4th, limped her home. I'd just done 300KM, so I was going to drop the oil and filter, recheck the valve clearances and run a compression test again and check to see if it was running lean or not too, to start playing with re-jetting for more oomph.
It's a bit naff, I'm not sure whether to drop the engine out the frame and tear into the gearbox or not. If I did, I'd send the frame off for powder-coating and really go for it, but I'm not sure if I enjoy it enough for the cost of doing that.
stevo as b4
PostPosted: 15:19 - 18 Apr 2015    Post subject: Reply with quote
Ouch, still at least you hadn't had the whole lump out before this happened, which would have been a bastard as you'd have to take it out again. Glad the engine was performing well before your box went all spazz though.
You love this bike too much to sell, and you've had it that long and done a lot to it, I just can't see you ever getting rid of your trusty TTR. I would say fix it and enjoy it again, or if you don't want to do a shed load of work on it right after just putting it back together again, then put it in the back of the garage for a month or so and go back to it when your ready.
I can see you wanting to change/upgrade the CRM before you ever sell this! Laughing
Fladdem
PostPosted: 19:20 - 18 Apr 2015    Post subject: Reply with quote
I posted on the TTR forum and apparently what can happen is the post that holds the return spring for the gear lever can snap off and cause spazziness inside the box.
I took the exhaust off today, to check out the state of the exhaust valves again, they seem a bit white for 300KM's of use and the plug looked a bit white too. Sick But I suspected it was running lean anyway, after the mods, re-jetting is going to be a fun game. As I was putting the header back on, the stud on the right hand side rotated round in the head and pulled itself out taking the thread with it. I'll probably need to heli-coil that stud back in now at some point. Embarassed
It may go on hold for the time being, like you suggest, I would quite like to get out and about on the GPz this summer, and after a set of tyres and fork seals, it's just a carb clean and plug change, should be all set for MOT then.
Fladdem
PostPosted: 11:38 - 01 Jun 2015    Post subject: Reply with quote
I had a look inside the TTR yesterday, turns out it was that post that had snapped.
http://i1302.photobucket.com/albums/ag134/Fladdem/DSC_00871_zpsijczl4aa.jpg
http://i1302.photobucket.com/albums/ag134/Fladdem/DSC_00881_zpsxqdiafmw.jpg
It's not very clear but that section of casting has snapped off from the post directly under the clutch. So, that needs gluing back on! Thumbs Up
Just_James
PostPosted: 13:16 - 01 Jun 2015    Post subject: Reply with quote
Blu tack Thumbs Up
Anyway... Mito?... RS50??
Current Bikes / Projects: 1999 Rieju RS1 50, 1999 Cagiva Mito 125
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 2008 Rieju RS2 50 , 1993 Honda NSR 125
Moo.
PostPosted: 17:53 - 22 Oct 2015    Post subject: Reply with quote
MOAAR!!
Just bought a TTR250 Raid for 750... Absolutely love it! Really fun bike, so much lighter than my Divvy 900 Embarassed
Mines running pretty tall gearing, was 14-44 when i got it, i put a 13 on the front.. But mines mainly road running.
A2 Passed 18/6/10
Fladdem
PostPosted: 23:51 - 23 Oct 2015    Post subject: Reply with quote
Mines running 14/48. Great! Thumbs Up
Before that incident happened, I could lift the front in fourth, sat down! It would still do about 80-85 flat out as well. Hahaha, no mercy, I was meant to be running it in as well. Twisted Evil
If you get the chance, the re-bore, I can't remember the size now, whatever the largest Brian at TotallyTTR's sells, Laughing and port and polish made a great difference. I think the shortened stainless header and the DG O pipe helped a bit too. I need to really sort that exhaust stud out and gear lever post. I was thinking that maybe it was running a bit lean because the header wasn't tight to the exhaust port. I should just buy a load of different jets really. Rolling Eyes
There is a gap of 2 years, 283 days between these two posts...
Fladdem
PostPosted: 22:01 - 02 Aug 2018    Post subject: Reply with quote
So after a long, long tine... I finally got it bodged and on the road.
I got the students at the college I work at to make me a bracket to support the gear lever return post. It mounts to where the kick start should have mounted, but mine wasn't fitted with one from the factory.
Got it mot'd. It passed with an advisory on front pads low and something else. The front brake is binding when it gets hot, I think it's the clamp on the fork leg trapping pressure in the bottom section. It could also be the fact it stood for three years. When I put a set of pads on, I'm going to put my braided lines on i had to help with braking and just because braided lines. Laughing
Will upload pictures when on the PC. Thumbs Up
stevo as b4
PostPosted: 23:06 - 02 Aug 2018    Post subject: Reply with quote
Yay! Back in the game with your old faithful! That's cool news dude!
Regards front brake, I'm sure a set of sintered pads, fresh fluid and a stainless line will really sharpen it up a treat!
Glad you got her back on the road anyhow! Thumbs Up
I'm waiting on a part from Germany so I can start ripping into my money pit 125 and getting it ready to fill the garden with clouds of blue smoke on my neighbours wash day. Smile
pepperami
PostPosted: 09:18 - 03 Aug 2018    Post subject: Reply with quote
For this, you get a cool rating Smile
Page 2 of 2
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 1.43 Sec - Server Load: 2.07 - MySQL Queries: 16 - CDN Objects: 41 - Page Size: 100.79 Kb
