| njanoskis |
 njanoskis L Plate Warrior
| evoboy |
 evoboy World Chat Champion
 Posted: 00:26 - 12 Jan 2015 Post subject: |
Needs lighter rollers. Trial and error is the only way you can do it when tuning the gearbox on a scooter.
The rollers in it may also be flat spotted.
The belt may also be due a change.
It may also need heavier clutch springs.
72 main jet seems very small on a 70cc kit and 21mm carb. Are you running an airbox? ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| mospeed |
 mospeed Renault 5 Driver
| njanoskis |
| njanoskis |
| BMWilliams |
 BMWilliams Two Stroke Sniffer
 Posted: 22:35 - 12 Jan 2015 Post subject: |
Find out what the standard jet size was then upjet to suit the parts just to make sure you have the right size to lessen the risk of running lean and seizing your lump
70cc Kit - 10-15% upjet
Exhaust - 5-10% upjet (depends on exhaust, some have been known to need up to 15%!)
Open Filter - 5-10% upjet
The new exhaust should have a set of rollers with it, 9/10 these normally help, if not buy a set of diff size rollers lighter than the ones you have, sounds like it needs lighter ones, not too light though, as it may affect your top speed
Trial and error though with the rollers and clutch springs ____________________ A good long ride can clear your mind, restore your faith, and use up a lot of fuel.
Never ride faster than your guardian angel can fly.
Ride, eat, sleep...repeat. |
The last post was made 11 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
