| Elliott Gee |
 Elliott Gee L Plate Warrior
| uberkron |
 uberkron Crazy Courier
| wr6133 |
 wr6133 World Chat Champion
| andys675 |
 andys675 World Chat Champion
 Posted: 20:53 - 11 Apr 2015 Post subject: |
definitely variator or belt related
there are usually 2 things required to derestrict or make a scooter go faster, this is true of most restricted scooters
1, the engine speed is restricted, usually by the exhaust, just replacing the exhaust is not enough and often harmful to your engine, as now it can do 10000 rpm at 30mph and the engine will wear out faster, a lot faster, creating a load more heat that may also cause seizure
2, the speed the back wheel can spin at is restricted, usually something in the variator needs removing, or replacing to allow the variator to expand which changes the gearing and allows the back wheel to spin faster = more speed, but without the extra revs of the engine speed being improved it won't go a lot faster ____________________ Some people feel the rain, others just get wet. |
| Iain. |
 Iain. Could Be A Chat Bot
 Posted: 09:18 - 13 Apr 2015 Post subject: |
TT pipes come with two sets of clutch springs, and a set of rollers unless you bought it used.
https://i.imgur.com/nkMEam5l.jpg
If it's new make sure you pull the restrictor out of the front pipe - pop a screwdriver in there and wiggle the little cone out, it's only tack welded in there.
https://i.imgur.com/ToIlVLcl.jpg
Fit the yellow springs, and the rollers which are from memory 15x12 3.5gr and you'll likely sort the issue. You'll also want a 6mm dellorto jet, probbably around size 68 if you've got an otherwise standard engine or it'll run lean at the top end costing masses of power & risking a heat seizure.
Biggest problem with the Aerox/TT pipe combo is the shitty Yamaha variator - TT pipe likes to be held at a nice consistant point in the rev range to get the best out of it, Yamaha variators don't hold speed precisely at all and dropping a few hundred revs can be enough to drop the engines power output drasticly - Variator upgrades the next thing on the cards.
Avoid the use of the word powerband if looking for sensible answers on here, however you've used it more or less correctly in this case. Given Underrated due to post being well written & making perfect sense  |
The last post was made 10 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
