Throttle won't snap back properly.
notbike
PostPosted: 23:59 - 21 Jan 2015    Post subject: Throttle won't snap back properly. Reply with quote
Discovered this just after putting on some heated grips, I think I fucked the cable up by twisting the throttle the wrong way (past the closed position) while twisting the grips into place.
Something felt like it snapped and the throttle wouldn't return at all, but when I opened up the housing the close cable had just slipped off the side of the throttle tube thing and was snagging between the throttle tube and the plastic housing.
Put the cable back in place and screwed it back up. Now instead of the throttle snapping immediately back to closed position upon release, it returns slowly.
So then a friend and I checked the old cables, one of them appeared to be warped (the close cable) so we replaced both cables that came in a pair. Still the throttle closes slowly.
The cables don't seem to be snagging on anything. They've been adjusted/tightened properly by my mate and the throttle works properly but it just closes slowly.
Lubed the handlebar/throttle tube. Lubed cables. Lubed the housing.
Suspected the cables might be snagged somewhere but they weren't catching on anything or being squeezed by anything.
Tried pulling the open cable and when releasing it, it snaps back. When its on the throttle tube and I twist it, it doesn't snap back but does it slowly.
Tube is lubed, every fucking thing is lubed and nothing is snagging. My actual throttle thing works on it's own without cables too.
Can't figure out what's causing it, two new cables connected properly and its still causing a problem.
The cables DID feel like they were snagging on something at some points (when we were moving the throttle tube about playing with the position to see if that effected it, which it did) but couldn't see where it was snagging, might have to take the tank off.
I have aftermarket lowered handlebars which could affect the position of the throttle cables, this could be causing it despite them being tensioned properly?
Thinking about taking it to a mechanic now cause we spent two days trying to figure it out.
SQL
PostPosted: 00:11 - 22 Jan 2015    Post subject: Reply with quote
My roxter grips took a little while to "bed" in the throttle was slow to return after about 2 weeks it was fine, I put it down to the extra cables taking a while to seat correctly.
Raffles
PostPosted: 00:24 - 22 Jan 2015    Post subject: Re: Throttle won't snap back properly. Reply with quote
What lubricant did you use between your handlebar and your throttle tube?
notbike
PostPosted: 00:42 - 22 Jan 2015    Post subject: Re: Throttle won't snap back properly. Reply with quote
Raffles wrote:
Meef wrote:
Newbie stuff
Take your throttle grip apart and remove the grease that you applied to the handlebar and the handle grip. These parts should be left dry or lubricated with a silicone based product.
Well we tested before applying any lube to the cables and it was the same slow return. Then we lubed it to see if that'd fix it, again slow return.
So it can't be the lube causing the problem because we tried with and without. Cables were not pre-lubed.
Raffles
PostPosted: 01:03 - 22 Jan 2015    Post subject: Reply with quote
I apologise for any confusion that may have been caused by the post editing that occurred during the Op's most recent post Sad
I am, however, still unsure whether or not your reference to lubrication refers to the cables or the throttle grip.
el_oso
PostPosted: 01:26 - 22 Jan 2015    Post subject: Reply with quote
have you set the freeplay right?
Duke 390
Car: Jeep Wrangler 4.0L
iooi
PostPosted: 06:28 - 22 Jan 2015    Post subject: Reply with quote
Either you pushed it on too far, so is snagging on the bar end. Or the bar end is tight against the grip.
FriendlyEllis
PostPosted: 07:17 - 22 Jan 2015    Post subject: Reply with quote
^^ This^^
Honda CB600F Hornet 2013 -> Kawasaki Z1000SX ABS Tourer 2015
notbike
PostPosted: 07:38 - 22 Jan 2015    Post subject: Reply with quote
Used a dry chain lube my mate had until it was dripping from bottom of cable. WD40 in the casing & on tube.
Free play has been set.
I don't have bar ends, the bars round off spherically. Also they snap back into place exact same position as before because there's a little hole where the casing with the kill switch latches into and the throttle tube fits into that.
FriendlyEllis
PostPosted: 07:41 - 22 Jan 2015    Post subject: Reply with quote
Are you sure????
notbike
PostPosted: 07:45 - 22 Jan 2015    Post subject: Reply with quote
Just ran downstairs and had a look and I'm sure the assembly snapped back into the same place. If that was the case it wouldn't screw back on.
This is mind boggling right now :S
FriendlyEllis
PostPosted: 07:46 - 22 Jan 2015    Post subject: Reply with quote
But your heated grip may be slightly longer than you old grip and catching on the bar ends (that a aren't there Wink )
notbike
PostPosted: 07:58 - 22 Jan 2015    Post subject: Reply with quote
They're not longer, they didn't need cutting down to size, they match the throttle tube's length.
It must be something up top though, could there be some kind of damage to the housing that holds the cables to the handlebar tube causing it to snag the cables?
c_dug
PostPosted: 08:34 - 22 Jan 2015    Post subject: Reply with quote
Did you use glue to stick the grips in place? I've had issues before where some glue has got where it shouldn't and caused issues. There was no way to tell what was going on until I'd remove the grips.
notbike
PostPosted: 09:06 - 22 Jan 2015    Post subject: Reply with quote
Yeah the grips were supplied with superglue, I glued grip to the throttle tube. None of it got between the tube and the handlebar though because we took that off and checked.
We spent quite a few hours taking the bike apart yesterday.
Side note, fucking got glue on my fairings Laughing
Minty
PostPosted: 09:07 - 22 Jan 2015    Post subject: Reply with quote
Yeah, I'd go with removing the grips and see if everything is then fine once again. Sounds like a friction issue if you are happy the cables are as they should be.
My fingers smell of your mum.
notbike
PostPosted: 09:08 - 22 Jan 2015    Post subject: Reply with quote
That's what I'm wondering this whole time, where the friction is coming from. I'm now thinking it's something I can't see, like how the cable sits inside the casing when I screw it back up, dunno if the casing could be damaged :S
Also, the throttle tube without cables in it moves around the handlebar easily so it can't be that causing it.
I'm convinced it isn't the cables because without the whole handlebar assembly, pulling on the cables lets the throttle snap shut.
PostPosted: 09:57 - 22 Jan 2015    Post subject: Reply with quote
Bike is a write off, I'll give you 5 ponds for it if the tank's full.
InB4 Paddy.
Right, that's not the problem.
So either it's the throttle grip sticking, or the return/close cable is sticking.
If you disconnect both cables, does the throttle grip rotate completely freely?
What about the close/return cable when you disconnect that and pull it on its own?
What does? The throttle body, down at the engine?
mudcow007
PostPosted: 10:32 - 22 Jan 2015    Post subject: Reply with quote
when i have messed about with throttle cables -
its always been poorly routed cables that have stopped the throttle returning.
make sure the cables are fitted properly
can you turn the throttle with the cables (disconnected from carbs)
oh an have you got bar end weights? they maybe dragging on the throttle tube thingy me bob
notbike
PostPosted: 10:44 - 22 Jan 2015    Post subject: Reply with quote
Throttle grip rotates completely freely when disconnected, no snagging/friction.
The return cable moves freely too when disconnected.
Yeah the throttle body, forgot what it was called Laughing
mudcow007 wrote:
Can you turn the throttle with the cables (disconnected from carbs)
Yeah, when they're disconnected from throttle body and attached to tube I don't feel snagging or friction. Same goes for attached at throttle body and not attached at throttle tube handlebar grip thingie.
Nope
The incredibly strange part is that all parts work individually or semi connected, but when the whole thing goes together this problem occurs, I'm 100% missing one bloody detail.
I'm starting to wonder if the problem could be when it's all connected up and the throttle is turned, the close cable must be getting pinched by something? The part that doesn't add up with that though is that it wasn't getting pinched when the throttle cable was disconnected from the throttle body but attached at the handlebar end.
Also another problem with this is I've tried it while varying the tension on the cables, from slack to tight.. so the idea that it could be too tight and making the cable move and get pinched doesn't add up either.
mudcow007
PostPosted: 10:55 - 22 Jan 2015    Post subject: Reply with quote
i know if i have one cable set too tight on my bandit carbs the throttle wont return (this was with brand spanking new cables aswell)
just make sure everything is seated properly,
maybe take the carbs out so the cables come straight out an see if the throttle works then - just an idea
notbike
PostPosted: 11:00 - 22 Jan 2015    Post subject: Reply with quote
Not sure how throttle cables work with a carb, mines fuel injected.
I'm gonna play with the tension on the cables again and see if that'll work.
Maybe the close cable needs to be tighter and the open needs to be a bit more loose.
PostPosted: 11:11 - 22 Jan 2015    Post subject: Reply with quote
Yeah, when [the cables are] disconnected from throttle body and attached to tube I don't feel snagging or friction. Same goes for attached at throttle body and not attached at throttle tube handlebar grip thingie.
Then it's goblins.
No, it's definitely goblins.
Offer is now 4 ponds, goblins are hell to shift.
notbike
PostPosted: 11:19 - 22 Jan 2015    Post subject: Reply with quote
I know borg, it sounds bloody impossible right, that's why I was actually debating taking it to a mechanic.
Literally mfw putting all the fairings back on after trying for hours.
https://media.tumblr.com/tumblr_m9gwxaC3ao1qdk18g.jpg
b422063
PostPosted: 11:37 - 22 Jan 2015    Post subject: Reply with quote
It's not a bad choice of route for the grips power cable is it?
The last post was made 11 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.94 - MySQL Queries: 16 - Page Size: 139.06 Kb
