ER6F 2014 Pass Light Button [FIXED]
thewhyoffry
PostPosted: 10:43 - 01 Apr 2015    Post subject: ER6F 2014 Pass Light Button [FIXED] Reply with quote
Hi all,
My pass light switch on my 2014 ER6F isnt working... I can manually switch high beam on/off using the switch but the pass (flash) trigger seems to be completely dead. No the end of the world as I rarely use it but would be nice to have it working.
Anybody experienced this before? - Loose connection or something?
Thanks!
The why of fry
J4mes
PostPosted: 10:53 - 01 Apr 2015    Post subject: Reply with quote
Isn't it under warranty on a 2014?
Or is it a bit of a pain to get it back to the dealer?
thewhyoffry
PostPosted: 11:37 - 01 Apr 2015    Post subject: Reply with quote
J4mes - It is indeed but its a bit of a trek and I like to have a tinker myself.
[UPDATE - FIXED]
There are two screws at the back which are easily removed and the unit comes apart.
On the rear where the pass trigger is located, there is a small screw holding it in place. I removed this and took a look at the rear of the trigger.
There was a small amount of dust and general grime between the spring so gave it a small clean with WD40 along with the connection and tested it. Works perfectly every time now.
https://i58.tinypic.com/2gvr292.jpg
The why of fry
grr666
PostPosted: 11:40 - 01 Apr 2015    Post subject: Reply with quote
Off out to check mine now... Laughing
thewhyoffry
PostPosted: 11:47 - 01 Apr 2015    Post subject: Reply with quote
Is yours playing up? Or just a precaution?
The why of fry
grr666
PostPosted: 11:51 - 01 Apr 2015    Post subject: Reply with quote
No I never use it either but that also means I don't know if it works or not. Everything else is fine but I
genuinely haven't used that function since checking the bike over when I bought it last year.
thewhyoffry
PostPosted: 11:54 - 01 Apr 2015    Post subject: Reply with quote
I mainly use it to give way to busses (because I'm nice like that,) but noticed that people had started ignoring my flashes. I thought how rude but realised this morning that it was simply not working Embarassed
The why of fry
The last post was made 11 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.54 - MySQL Queries: 14 - Page Size: 52.89 Kb
