exhaust for custom ybr
sutty86
PostPosted: 23:50 - 23 Feb 2015    Post subject: exhaust for custom ybr Reply with quote
Mine is on its last legs.
Need a new one before mot.
Problem is its a custom ybr so I think the different to the normal exhausts well look really different.
Is there any aftermarket cheaper exhausts to fit then the expensive hard to get hold of custom .
PostPosted: 01:03 - 24 Feb 2015    Post subject: Reply with quote
Which part of it is rotted?
sutty86
PostPosted: 01:42 - 24 Feb 2015    Post subject: Reply with quote
I'm probs over exaggerating that's its rotting but its defiantly seen better days.
Chrome part at the rear has worn off where screws are so I'm ripping that off
Will take some photos tomorrow
ADSrox0r
PostPosted: 14:06 - 24 Feb 2015    Post subject: Reply with quote
Heh, I used to have a YBR Custom. Yes the exhaust is made of chocolate. Yes, a new Custom exhaust will rush you about 500 quid. No, another exhaust doesn't quite fit on without some modification to the hanger bracket. Bit of welding and bracket manufacturing required m'fraid.
If you can weld up the existing exhaust then do so and get shot of it. That's precisely what I ended up doing.
PostPosted: 20:35 - 24 Feb 2015    Post subject: Reply with quote
Jesus wept.
Does the Yamaha-Jianshe exhaust have an O2 sensor?
If not, then the Jianshe JS125-6c exhaust might fit.
https://www.learnerlegal.com/125cc-cruisers/jianshe-js125-6c-black-/prod_1136.html
Learner Legal / LS Imports stock plenty of spare parts although they don't exactly headline it. Prices were historically pretty good.
ADSrox0r
PostPosted: 20:51 - 24 Feb 2015    Post subject: Reply with quote
No, no O2 sensor it's just insanely expensive because no-one stocks it and they don't sell many.
tbh, better off looking at breakers yards or eBay. That said, the shitty mild steel will be just as knackered on a used one. I found they'd only last about two seasons if you were lucky.
The Jianshe exhaust won't fit btw, again the hanger bracket is the cockblock.
zark
PostPosted: 14:25 - 25 Feb 2015    Post subject: Reply with quote
Can't work out if this on ebay is a custom exhaust for a YBR or an exhaust for a Custom YBR?
£96 ponds tho
PostPosted: 16:30 - 25 Feb 2015    Post subject: Reply with quote
Sad
Was it a Jianshe one you tried?
£96 ponds tho
... and I'd wonder if that's a Jianshe part. I mean, part made for the Jianshe branded bike, I'd expect it'll be a Jianshe-made part either way. Wink
wr6133
PostPosted: 16:36 - 25 Feb 2015    Post subject: Reply with quote
If the end can is shagged but the downpipe is saveable then chop the can off, sand, VHT paint and wrap the pipe and bolt one of these on the end https://www.classicbikeshop.co.uk/slash-cut-extension-exhaust-1-3-4.html . Paint, wrap and the end can under £50 all in.
YBR Ric
PostPosted: 18:12 - 25 Feb 2015    Post subject: Reply with quote
£96 ponds tho
It's for the custom YBR - the Yamaha model number is given as 27S1
The standard YBR (ED) for example has a model number of 3D99.
PostPosted: 18:45 - 25 Feb 2015    Post subject: Reply with quote
What, you mean actually customise a YBR Custom? Eh? Laughing
sutty86
PostPosted: 22:52 - 25 Feb 2015    Post subject: Reply with quote
https://s4.postimg.org/jitc3j5rt/IMG_20150225_192629.jpg
https://s2.postimg.org/6z7prweb9/IMG_20150225_192615.jpg
https://s10.postimg.org/ck0v7zkth/IMG_20150225_192645.jpg
https://s9.postimg.org/4zvv621kb/IMG_20150225_192658.jpg
Is it bad??? Or can I save it
If so any tips
Ta
wr6133
PostPosted: 23:12 - 25 Feb 2015    Post subject: Reply with quote
It could be a first.
If so any tips
Ta
Try cleaning it up with some sandpaper and elbow grease, you'll get an idea of how set in that rust is then, I'd bet it's not as bad as you think. If it cleans up well then VHT paint it, if it's a bit rough then VHT it and then exhaust wrap it (to hide the roughness).
sutty86
PostPosted: 14:45 - 26 Feb 2015    Post subject: Reply with quote
Thanks guys
Just bought some sandpaper and wet and dry paper today also hacksaw to saw through metal brackets which have been bent and corroded...
Just going to vht it matt black...
The last post was made 11 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 3.89 - MySQL Queries: 13 - Page Size: 82.87 Kb
