Drift Stealth 2 - Flaws
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3, 4  Next
parahandy
PostPosted: 18:58 - 21 May 2016    Post subject: Drift Stealth 2 Flaws Reply with quote
I bought a Stealth 2 and it froze after a few months use and it would not power up. Tried all suggested fixes from Drift no difference, it was replaced under warrenty as it was identified as faulty. Exactly the same thing happened with the replacement Camera, just died and would not charge. There has been some suggestion that certain memory cards can lead to issues. I used two Drift recommended cards and still had problems.
As a company I like Drift and certainly when the Stealth works its gives excellent results. If I am correct the Drift Ghosts don't seem to have the same issues as the Stealth2 models.
M.C
PostPosted: 20:39 - 21 May 2016    Post subject: Reply with quote
I know I've got the budget model (Drift 720), but with the amount of software glitches these cameras have I wouldn't have another.
The camera froze the other day when I stopped recording, I expected there to be a corrupted file (which has happened before), there wasn't even that. Even simple stuff like connecting it to your PC, the camera can be really temperamental, and it does odd of stuff like failing to recognise memory cards.
There is a gap of 235 days between these two posts...
oldpink
PostPosted: 00:55 - 12 Jan 2017    Post subject: Reply with quote
just bought a SJ4000 for £13 free delivery from fleabay
should have it by fri so will see how good it is and post back when I get time to test it
one question not sure about mounting it on the bike or helmet ??
if its any good I'll buy another and have one on the bike and a helmet mount
M.C
PostPosted: 01:10 - 12 Jan 2017    Post subject: Reply with quote
Was it a genuine one? I believe they started using the branding sjcam, although that's probably been copied by now Smile
oldpink
PostPosted: 01:21 - 12 Jan 2017    Post subject: Reply with quote
looks legit, listed as an SJ4000 in the add, has all the correct spec's
comes without memory card but I have a few spare ones
there are a load on Ebay for the same price UK based and has 30 day money back and year warranty
so for £13 its no big loss Thumbs Up
PostPosted: 10:08 - 12 Jan 2017    Post subject: Reply with quote
None of the £13.xx ones I can see on eBay are SJCAMs.
Funny old world where we can talk about fake vs genuine knock-offs.
Landy10
PostPosted: 11:34 - 12 Jan 2017    Post subject: Reply with quote
Ive had an sj4000 for two years. never had an issue with it.
Bought a ram mount ball and bar so I could mount it on the handle bar clamp. Works great
TheArchitect
PostPosted: 12:45 - 13 Jan 2017    Post subject: Reply with quote
I bought a legit SJ400 wifi version for holiday videoing - paid £45 if I remember correctly. Can't fault it. Image quality is fantastic and very stable, whether it be low light, bright light or under water.
As for mounting it, there are dozens of hinges and elbows you can buy on ebay to get it mounted in almost any position you want. Mine came with an array of various attachments and mounts, most of which I will probably never use.
One thing to make sure is don't scrimp on the sticky mount and go for the genuine 3M (or GoPRo) ones. Last thing you want is the camera to fly off at speed.
GSXR 600 K6 - Stolen
MT09 - Almost stolen
M.C
PostPosted: 13:25 - 13 Jan 2017    Post subject: Reply with quote
<TrumpSaysChina.mp4>
conker
PostPosted: 18:35 - 13 Jan 2017    Post subject: Reply with quote
My stealth 2 started making a loud static noise from the speaker when it was powered off. It now no longer turns on.
oldpink
PostPosted: 17:29 - 16 Jan 2017    Post subject: Reply with quote
well the camera arrived this morning
came with a basic flat mount, a bar mount and a 90 deg adapter no mains power but USB lead supplied
couldn't find a single flat surface on the bike I can mount it to so ordered a bag of adapters and a load of curved & flat mounts (£5)
in order to test it I stuck it on top of my helmet with the flat mount which was not ideal as only half the pad is in contact
but went a run and happy to report it worked fine and more than happy with it as it will do what I need it to do
and at £13 I'll be getting one or two more
definitelyinc...
PostPosted: 18:05 - 16 Jan 2017    Post subject: Reply with quote
A video would be nice Thumbs Up
oldpink
PostPosted: 18:08 - 16 Jan 2017    Post subject: Reply with quote
I'll put one up soon Thumbs Up
There is a gap of 1 year between these two posts...
R1stu
Shrek!
PostPosted: 15:19 - 17 Jan 2018    Post subject: Reply with quote
I've had issues with my stealth too, charging issues from day 1. Customer service although quick to respond just told me to take back to the dealer.
I bought it from the NEC bike show. Anyway, I would have it in charge overnight and it still would be flat the next day or at 10% and turn off almost instantly.
CS told me to charge without the memory card connected. I did this and it charges a lot faster now.
The main issue is the door, keep losing it as taking it off to charge is a pita.
Its been in charge next to me now since 9am and only on 50% charge, however, I am using a £land charger.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
andym
PostPosted: 16:07 - 17 Jan 2018    Post subject: Reply with quote
A year later:
https://s2.quickmeme.com/img/b4/b41e05332deeb691f5b2ba0b867c0e3857d71876663b8ab3cf67210878692057.jpg
PostPosted: 16:19 - 17 Jan 2018    Post subject: Reply with quote
Glue a couple of cable-ties to the body and the door to simulate the hinge that should have been designed into it. Obviously once it's out of warranty.
Moo.
PostPosted: 20:31 - 17 Jan 2018    Post subject: Reply with quote
I'm still using an old Drift HD 1080 jobby. About 4/5 years old now, Holds a charge for about 1 and a half hours on original battery (1100mah). Quality at night ain't great but it jobs a job!
A2 Passed 18/6/10
struan80
PostPosted: 20:44 - 17 Jan 2018    Post subject: Reply with quote
So what's deemed as the best value for money camera with a long battery life at the moment? Cheap is good.
kerr
PostPosted: 20:47 - 17 Jan 2018    Post subject: Reply with quote
My drift ghost hd gave up the ghost recently, after only a couple of years of weekend warrior use Evil or Very Mad
Trying to source a decent cheap cam with removable memory and battery that isn't a box that sticks out a mile.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
M.C
PostPosted: 23:12 - 17 Jan 2018    Post subject: Reply with quote
Is that regular use? I rode 40mins somewhere, and was disappointed the battery died halfway back.
Moo.
PostPosted: 08:25 - 18 Jan 2018    Post subject: Reply with quote
Everyday too and from work. Gets charged up from the usb at work, then does a 45 mins journey home, and 45 mins to work the next day
A2 Passed 18/6/10
M.C
PostPosted: 08:26 - 18 Jan 2018    Post subject: Reply with quote
Is that at 1080 or 720?
doggone
PostPosted: 08:54 - 18 Jan 2018    Post subject: Reply with quote
Alternative batteries for Drifts are cheap on ebay, I got an external USB charger and spare for about £7 but only used it a couple of times as original lasts a good two hours (Ghost HD).
The weak spot on them for me has been mini USB breaking away inside.
I had one replaced under warrant then fixed it again myself later.
sickpup
Old Timer
PostPosted: 14:40 - 18 Jan 2018    Post subject: Reply with quote
Why do people not buy a camera that runs from the bikes battery?
Moo.
PostPosted: 08:29 - 19 Jan 2018    Post subject: Reply with quote
1080 although I only film at 720 for more space on the card
A2 Passed 18/6/10
The last post was made 6 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.43 - MySQL Queries: 17 - Page Size: 133.84 Kb
