Darkside |
Darkside Trackday Trickster
Sparks! |
Sparks! Sir Tart-a-lot
Posted: 13:56 - 04 Aug 2004 Post subject: |
You'll get a better response if you post your questions in the right categories
I'd say you'd want to drain the petrol and put fresh in, other than it /should/ start after a few goes and run ok, once it's had a nice ride it should be back to running sweet again. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Spiral |
Spiral Traffic Copper
Posted: 08:57 - 06 Aug 2004 Post subject: |
Yeah put fresh petrol in your bike i think it goes of after a while, check chain is okay ie. greased, and tyres ie. pressure also make sure your battery is okay might need charged.
Can't really think of anything else at the moment. ____________________ ****NORTHERN IRELAND NEWSFLASH!!**** According to a recent survey, 94% of loyalists said the best sex they ever had was in the shower; the other 6% haven't been to jail yet.*** |
ts50x0 |
ts50x0 Spanner Monkey
Robby |
Robby Dirty Old Man
Posted: 22:49 - 10 Aug 2004 Post subject: |
Agree with all of the above. I would use a few drops of pre-mix down the sparkplug holes and kick over a few times with the ignition off rather than actual neat 2-stroke, spreads about more easily and less likley to make your plugs oil-up immediatley.
Definatley put in fresh fuel, it may be worth opening the drain screw at the bottom of the carbs and allowing some fresh fuel to run through the float bowls too, the old petrol may well have evaporated and you don't want your first action to be sucking any deposit straight up into the jets. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Retro-Man |
Retro-Man Traffic Copper
The last post was made 19 years, 252 days ago. Instead of replying here, would creating a new thread be more useful? |
