 bidzian L Plate Warrior
 Rogerborg nimbA
 Posted: 21:58 - 26 Mar 2015 Post subject: |
That's a CG125 copyengine. The filter is a clean-and-reuse mesh behind that big bolt (23mm IIRC) on the bottom edge of the LHS of the engine.
https://rogerborg.dnsd.info/cg-copyengine-filter-plug.jpg
It's a soft alloy nut that you might find needs a bit of persuasion. I'd recommend getting a hex socket that fits it rather than rounding it off with a spanner.
Also, be careful when replacing the sump drain plug. Don't over-tighten it. It looks like there's no crush-washer fitted at the moment - I'd add one. ____________________ Biking is 1/20th as dangerous as horse riding.
