IAM U turn the right way with controlled front brake
Bike Chat Forums Index -> Biking News & Rumours
Val
PostPosted: 21:45 - 30 Mar 2015    Post subject: IAM U turn the right way with controlled front brake Reply with quote
I present you IAM U turn - correct way to do it with just a pinch of a front brake Laughing
https://www.facebook.com/video.php?v=786831904743186
PostPosted: 21:51 - 30 Mar 2015    Post subject: Reply with quote
He's clearly not heard of Windows movie maker.
Can skip the whole first minute and a bit.
Doovy
PostPosted: 23:16 - 30 Mar 2015    Post subject: Reply with quote
Foot / bike down fail.
PostPosted: 09:55 - 31 Mar 2015    Post subject: Reply with quote
https://pective.com/m/walkers-crisps-packet
cheeseman
PostPosted: 09:59 - 31 Mar 2015    Post subject: Re: IAM U turn the right way with controlled front brake Reply with quote
Val wrote:
I present you IAM U turn - correct way to do it with just a hinch of a front brake Laughing
How embarrassing! But why do you say IAM? It looks like Police rider training to me.
XJ600S->Sprint ST 955i * ; Now ST1100 + W650
Skudd
PostPosted: 11:25 - 31 Mar 2015    Post subject: Reply with quote
Someone posted about linked brakes being the cause, I don't think so myself. However I use the front on most of my U-turns unless really messy roads/tracks. I also have linked brakes.
lihp
PostPosted: 12:07 - 31 Mar 2015    Post subject: Reply with quote
I've only experienced linked brakes once, but can you correct me if I'm wrong?
I believe that the brakes are only linked when using the front, and that if you use the rear, then ONLY the rear is used?
Skudd
PostPosted: 12:11 - 31 Mar 2015    Post subject: Reply with quote
Both are connected. Front biased more though.
barrkel
PostPosted: 16:50 - 31 Mar 2015    Post subject: Reply with quote
There's no one single system. On Honda scooters with linked brakes, there's typically three pistons on the front caliper and one piston on the rear, the front brake applies two pistons on the front, while the rear brake applies one piston on front and one piston on rear.
On the VFR, it's much more complicated. All the brakes have three pistons per caliper. The rear brake applies two pistons on rear and one piston on the front left caliper. The front brake applies the 5 remaining front pistons, but the left hand caliper is able to tilt in its mounting. This tilting action is only actuated when the brake is applied and gripping the disc, so that the forward motion tries to rotate the caliper. The tilting action applies pressure to a slave brake cylinder, which in turn actuates the remaining piston in the rear brake caliper (not directly though, oh no, it's mediated by a PCV, "proportional control valve").
Thus, on the VFR, if you apply the rear, it's mostly rear, but also some front, which is also able to feed back into the rear. If you apply the front, it's almost all front, but a little bit gets fed back into the rear. You get most braking power by using both simultaneously.
https://jay-d.com/ecto/brakebleeding/Part1-2.jpg
The rear brake on the VFR is a bit theoretical though. The swingarm presents a large surface for chain oil to soak onto, if not from fling, then from the chain guide / swingarm protector. The rear brake caliper is mounted underneath the swingarm, and chain oil tends to spread down there. After a long tour with scottoiler, my rear brake caliper, pads etc. are invariably coated in oil.
Pie-Roe
PostPosted: 20:26 - 31 Mar 2015    Post subject: Reply with quote
On my first x11 I boiled the brakes limping it home with the rear brake wedged on.
Quite annoying it was.
Vracktal
PostPosted: 21:47 - 31 Mar 2015    Post subject: Reply with quote
At first glance I was willing to give him a pass because I know how tricky boxer BMW linked brakes can be, especially on the RT where it's crossfeed (front to rear and rear to front, my BMW is front to rear only.)
But on closer inspection his right foot is down when he's turning so i'm going to go with hamfistedness. For shame, dibble.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
lihp
PostPosted: 21:58 - 31 Mar 2015    Post subject: Reply with quote
Don't be daft! They're highly trained riders, that's why they can do 80 in a 60!
Albigularis
PostPosted: 22:52 - 31 Mar 2015    Post subject: Reply with quote
Surprised they never told him in his advancedness how to lift a bike up properly.
There was two of them and they made it look a struggle...
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
The last post was made 11 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 81.98 Kb
