| ryosaurus |
 ryosaurus L Plate Warrior
| mudcow007 |
 mudcow007 World Chat Champion
| ryosaurus |
| bikenut |
 bikenut World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:53 - 20 Mar 2015 Post subject: |
It won't rotate? No movement at all?
Have you tried jacking the engine up to take the weight off of it?
WD-40 is not a release agent. I'd switch to PlusGas or another actual penetrating fluid. ____________________ Biking is 1/20th as dangerous as horse riding.
| ryosaurus |
| mudcow007 |
| bikenut |
| zark |
 zark Trackday Trickster
| c_dug |
 c_dug Super Spammer
 Posted: 14:13 - 20 Mar 2015 Post subject: |
You need a bigger hammer.
Actually, pressing it through would probably be your best bet but I'm not sure how you'd do that with tools you're likely to have around the house.
One thing though, if it was me I'd do something to protect the end of the thread, any more flaring and you'll struggle to get it through the hole. Ideally you would have had a nut on it from the start, not sure what you can do now because there's bugger all hope of getting a nut on the end of there as it is.
Maybe work it back with a file and get a nut on the end before bashing it any more. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| WD Forte |
 WD Forte World Chat Champion
| N cee thirty |
 N cee thirty Banned
| Teflon-Mike |
 Teflon-Mike tl;dr
| killerbanjo |
 killerbanjo Renault 5 Driver
| Sload |
 Sload World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 01:51 - 21 Mar 2015 Post subject: |
SDS drill bit trick can be remarkably effective.... even an old fashioned percussion-hammer drill can do the job surprisingly well... was a bit of improvisation I employed many years ago when I no longer had access to shared work-shop with the wonders of a pneumatic chisel!
You can a get (and I now have) SDS chisel bits, and if you can get one to fit in countersink in end of the bolt, work just as well as blunted old masonry bit.
Trouble usually is that the steel bolt has 4" of shank in the alloy of the crank case, and only 1/4" either end through the steel lugs on the frame. A-N-D its in one of the most least seen crud traps on the bike, with little reason for it ever to be touched. & You get higher rate of corrosion between dissimilar metals on the long bit of bolt, effectively welding bolt in place.
HINT: - Brute force tends to see the weakest link give first.. A-N-D.. that tends to be the human on the end of the hammer, shortly followed by the frame lugs.
Craftiness & patience often works better than gross force, power-tools and fire!
When it comes to cutting, the humble hand-powered hack-saw is your best friend.. may take elbow grease, but once you have a slot for it to follow, it is often the most accurate and least destructive way to cut....
If you have undone the nut then the clamping pressure on the the nut end engine plate is relieved, but often not relieved the head end if bolt cant move in cases.
Big metal of the hex-head can be taken off with an angry-grinder, but last 1/4" or so should be taken flat to the plate with a file. That can give enough 'play' to be able to use a pry-bar to waggle the engine plate away from the crank-case, enough to get a hack-saw blade in between casing and plate to cut through bolt.
Do both sides; motor should drop out.. HINT:Straps/rope/Old coat-hanger wire, or similar should be used to hang the motor from the frame's back-bone until you are ready to 'catch'... but bits of bolt going through frame lopped off, should come out, without too much risk of buggering the frame plates.
How to get the shank of bolt out of the crank-cases?
Well, with the engine out the frame; you do have more options and more access.
a) You can return to the SDS drill trick and or big hammers, with the motor laid on its side so yo are bashing the thing into the floor, rather than knocking the whole bike side-ways... change of orientation alone may be all you need to direct force where required.
b) Engine reconditioning type places often have big presses, and for price of a pint, might pop the motor on its side under 20 tons to make bolt budge...
c) Back to the hack-saw; carefully slot the 'boss' the bolt passes through in the crank-cases, along the line of the bolt, until you touch steel. Boss now has a C-shape cross section instead of an O-section, and can be expanded (a little) more easily; while you can also get penetrating oil more directly where its needed. Bit of oil, bit of bashing and the thing will usually give up its grip on the shank.
Structurally; as long as you haven't taken a huge chunk out, a small slot wont effect the strength of mounting when re-fitted; it's mainly taking load along the length of the bolt that is usually a pretty slack fit that hole any way, the torque reaction shared by four or so other mounting points; but if it irks or a cosmetic repair wanted, the crack can be filled with lumi-weld or similar. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| ryosaurus |
| DMCpro |
 DMCpro Traffic Copper
The last post was made 10 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
