| map |
 map Mr Calendar
 Posted: 11:19 - 05 Aug 2004 Post subject: Asking for advice on fuel blockage/tank cleaning |
As the title says. Moved (lifted/tilted) tank last night to check air filter. This morning had difficulty starting and running. Fuel gauge shows enough fuel in tank (within its usual guesswork). Put onto reserve and picks up okay
So I guess I've moved some crud in the tank. I wondered what advice I could get to clean it out. I'll take the tank off but what's best way to get the crud out. Will try and remove fuel tap but it looks pretty seized.
How far do you think I should go down into checking the carbs?
In the past I've took the tank off one of my old 125s and had a large amount of shaking to get the rust out. Finished off by putting radiator cleaner in with boiling water to try and put what was left in solution. Then had hassle shaking all the water out. Would this method be recommended for a bigger bike (an old inline 4)?
At the moment this is my only form of transport so need to get this problem sorted ASAP.
Thanks in anticipation  |
| Ste |
 Ste Not Work Safe
| Big Pete |
 Big Pete Spanner Monkey
| map |
 map Mr Calendar
 Posted: 14:45 - 05 Aug 2004 Post subject: |
| wisebeuy |
 wisebeuy Nova Slayer
 Posted: 18:04 - 05 Aug 2004 Post subject: |
OK, have had a bit of experiance in this field.
Mostly would say what everyone else has, but a couple of points.
First, drain ur tank, then like Big Pete says, clean out with some nuts, and flush with plenty of petrol.
Second, take an air compresses and blow thru the tap and really get any crap cleared.
Also, even tho it seems to work fine on the reserve tank, give the carb a clean anyway, as small bits of crap can easily block the jets and cause power loss and instability.
After cleaning the tank, you are always going to be left with some crap in it which is going to get into the fuel, so buy an inline fuel filter to go from the tank to the carb if u don't have one already. |
| map |
 map Mr Calendar
 Posted: 00:09 - 06 Aug 2004 Post subject: |
Thanks for the advice. Problem sorted. Took tap out of tank and gave good clean. Shook out tank but didn't get much gunk out, although fuel was a little yellowish, so worth doing. Put back together and everything okay
Happy it was as I went to fill up with fuel and forgot the mobile so would have been stuck if it failed
Bike is having a service next week as can hear the tapits ticking and I want the carbs balancing.
 ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
The last post was made 22 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
