Retro Cannondale project.
sickpup
Old Timer
PostPosted: 13:43 - 04 May 2015    Post subject: Retro Cannondale project. Reply with quote
I much prefer the riding position on old bikes and I have a particular like of old Cannondales from 1989 onwards.
Among the various bits I have packed away is an 18" Cannondale MTB frame from 1990 which is the perfect size for me.
I recently managed to pick up another frame (extremely small 14") with a set of Pepperoni Aluminium forks for £49. The forks being the genuine Cannondale ones of the era with the steerer cut to the correct length for an 18" frame.
I also have an almost original Specialized Stumpjumper from 1989 that I got for free with a mixture of DX and XT but the frame is a 22" so unusable for most normal size people, nearly all the parts will be swapped over to this frame to create a cheap usable quality bike. In fact even the headset if it is any good will be used on the 14" frame just so the forks don't fall out of it in storage.
After a dry build the frame will be powder coated, not sure what colour yet and re-decaled so should look pretty original not that originality is the plan.
So far the bottom bracket has been fitted as well as the forks using a Stronglight A9 headset and a bottom race neoprene seal. A 135mm Girvin flexstem has also been added. The seatpost will probably be replaced with either a suspension type or a 350mm Kalloy.
At the moment it looks like this.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150504_130149.jpg
To give you an idea of the size of the frame going into storage.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150504_132640.jpg
PostPosted: 15:35 - 04 May 2015    Post subject: Reply with quote
I'm going to go ahead and presume, given the general cleanliness of that kitchen which suggests it is not in regular use as a bicycle workshop, that you've been left by yourself over the weekend. Laughing
sickpup
Old Timer
PostPosted: 18:25 - 04 May 2015    Post subject: Reply with quote
Not left alone. The kitchen is generally that tidy even though I use it as a workshop. Today we have been doing house work so I decided to assemble the bits together to get them out of the way before we cleaned the kitchen.
sickpup
Old Timer
PostPosted: 20:16 - 04 May 2015    Post subject: Reply with quote
There is some damage to the frame that will need cleaning up before powder coating. Scrapes on the top tube and chain suck. It's not too bad but will need dressing.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150504_204638.jpg
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150504_204629.jpg
sickpup
Old Timer
PostPosted: 17:14 - 05 May 2015    Post subject: Reply with quote
Thought I'd take a photo with wheels and tyres on just to see the proportions and how it looks.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150505_180708.jpg
PostPosted: 22:50 - 05 May 2015    Post subject: Reply with quote
Let me know where you go for powder coat and how much is costs I've a frame and forks that need doing too.
sickpup
Old Timer
PostPosted: 22:57 - 05 May 2015    Post subject: Reply with quote
About £70 at Armourtex.
spnorm
PostPosted: 21:01 - 10 May 2015    Post subject: Reply with quote
I've still got a 1991 Trek 970 mountain bike at my parents house which I've owned since new. It's very original and has a U.S. Made steel frame and the paintwork is still in very good condition Cool
I sometimes think I should sell it as there's a market for retrobikes, but it has a lot of sentimental value
sickpup
Old Timer
PostPosted: 13:41 - 05 Jun 2015    Post subject: Reply with quote
A little bit further along with this.
A new Cannondale seat for £15 from Evans and a set of BBB Skybars as I'm getting old.
The Deore thumbshifters are fitted along with 2 finger Deore brake levers. Also fitted a Deore Chainset with new 48 tooth chainring.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150605_140546.jpg
PostPosted: 14:01 - 05 Jun 2015    Post subject: Reply with quote
What's the funky stem?
sickpup
Old Timer
PostPosted: 14:18 - 05 Jun 2015    Post subject: Reply with quote
Its an old school flex-stem with an elastomer to absorb road shock. Not suspension as such but an added comfort thing.
sickpup
Old Timer
PostPosted: 20:18 - 13 Jun 2015    Post subject: Reply with quote
Started cabling it up
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/IMG-20150613-WA0000.jpeg
sickpup
Old Timer
PostPosted: 15:56 - 22 Jun 2015    Post subject: Reply with quote
A couple more pics of the work on it.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150622_164127.jpg
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150622_164104.jpg
sickpup
Old Timer
PostPosted: 16:18 - 28 Jul 2015    Post subject: Reply with quote
Ran in to an odd problem, the sort you get when working on old bikes. The frame the bits were removed from had a 130mm spacing on the rear drop outs and the cannondale frame has 135mm spacing, its best not to pull aluminium frames in so it needs a new rear axle.
Luckily the M732 rear hub was a transition year and was available in both 130 and 135 spacing so off to ebay and there was a seller with NOS 135mm axles, once delivered I stripped down the hub and discovered that after 26 years or so the bearing and cones were perfect.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150728_164557.jpg
Heres the new axle beside the original, only slightly longer but enough longer.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20150728_164249.jpg
A quick regrease with bearing grease and the hub is back together, now the rear wheel needs redishing 2.5 towards non-drive side.
UnknownStuntm...
PostPosted: 16:32 - 28 Jul 2015    Post subject: Reply with quote
I know of two people who successfully 'claimed' on Cannondale's lifetime warranty by inserting threaded rod, washers and nuts between the dropouts and tightening. Surprising just how far they go before they let go.
I couldn't bring myself to go through with it.
Loves it, I do.
sickpup
Old Timer
PostPosted: 23:21 - 10 Oct 2015    Post subject: Reply with quote
Finally finished putting this together and have taken it out for a couple of small rides to the shops. It doesn't have the correct rear wheel in it, I've yet to re-dish it but it makes a nice simple bike with a good ride. None of this heavy weight suspension that seems to plague modern bikes so it is nice, light and comfortable to ride.
Next I have to strip it down and get it powder coated but I think that can wait until I am bored in the new year. At the moment I am happy for it to look the way it does, slightly rough but very old school.
https://i945.photobucket.com/albums/ad297/750RK/Bicycle/20151010_092416.jpg
Final spec is Deore throughout with a Deore XT rear mech.
sickpup
Old Timer
PostPosted: 10:56 - 29 Oct 2015    Post subject: Reply with quote
The rear wheel is changed and I've used it a few times now. It rides well and is remarkably spritely in its acceleration and handling.
One problem has appeared, the bottom bracket is too short so you can't shift onto the bottom ring. Not a problem on the road but could be a problem if I ever take it off road so will need to sort this out when I get a chance but at the moment I am just enjoying using it.
The last post was made 10 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 95.93 Kb
