Chain too tight when I sit on the bike
Az
PostPosted: 23:49 - 06 Jun 2015    Post subject: Chain too tight when I sit on the bike Reply with quote
When I'm off the bike the chain has good amount of play in & then when I sit on the bike the chain gets extremely tight, as in no play what so ever.
Checked with two friends' bikes, and their chains get no were near as tight when there sat on their bike and their chains have similar tension to mine when off the bike.
C&S have plenty of life. My chains only ever needed adjusting 2 times in the 8 months it's been on, it's fairly well looked after too.
What could cause my chain to go super tighter when weight is on the bike in comparison to when there's no weight on the bike? (I know the chain tightens up when you sit on it, but it shouldn't be getting this tight)
Any ideas? As I don't want to be riding a chain that's stupidly tight for the obvious reasons. Will take a video tomorrow as that'll give you all a much better insight to my problem.
Raffles
PostPosted: 23:57 - 06 Jun 2015    Post subject: Re: Chain too tight when I sit on the bike Reply with quote
Az wrote:
Any ideas?
Adjust the fucker.
lihp
PostPosted: 00:03 - 07 Jun 2015    Post subject: Reply with quote
Loosen the chain then?
Az
PostPosted: 00:05 - 07 Jun 2015    Post subject: Reply with quote
First thing I did, makes no real difference.
Will take a video tomorrow, it'll explain it a bit better.
CaNsA
PostPosted: 00:17 - 07 Jun 2015    Post subject: Reply with quote
Inb4 tightspots.
PostPosted: 00:24 - 07 Jun 2015    Post subject: Reply with quote
My 1200 is a pain for the chain getting a LOT tighter when you do the wheel spindle up properly (ie, you adjust the chain, get the tension right and then tighten the spindle up and most of the free play disappears).
As such check the tension is right . Sitting on the bike will tension the chain a touch, but that is why there needs to be some slack there.
But Cansa could well be right on the tight spots as well
K
doggone
PostPosted: 00:27 - 07 Jun 2015    Post subject: Reply with quote
Suspension geometry changes the distance between sprockets as it goes down - always best to check it's not too tight by lying over the seat if a second fat person is not available to sit on it while you check.
PostPosted: 00:55 - 07 Jun 2015    Post subject: Reply with quote
You should check the chain when sat on the bike. Most people don't because its obviously easier on the center or paddock stand and to be honest, I haven't found it make a huge difference which ever way you do it so I'd be a bit worried about your method.
Triumph Trophy Launch Edition
PostPosted: 07:38 - 07 Jun 2015    Post subject: Re: Chain too tight when I sit on the bike Reply with quote
https://static.guim.co.uk/sys-images/Guardian/About/General/2010/1/13/1263405794011/Pork-Pies-001.jpg
OR
https://images.motorcycle-superstore.com/productimages/300/0000-ohlins-type-39pr-shock-absorber.jpg IS https://www.goteborg2013.com/wp-content/uploads/2012/06/450x300_helena_engman.jpg
Taught2BCauti...
PostPosted: 08:55 - 07 Jun 2015    Post subject: Reply with quote
It's all about the Angle of the Dangle.
Chain adjustment should be done when the centre of the front sprocket and the centre of the rear sprocket, is on the same line as the centre of the swing arm.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Pete.
PostPosted: 09:03 - 07 Jun 2015    Post subject: Reply with quote
K
Most all of the Suzukis I have owned have suffered this. You always have to check the chain tension after torquing the spindle nut.
a.k.a 'Geri'
john24ssj
PostPosted: 09:04 - 07 Jun 2015    Post subject: Reply with quote
This video should explain it pretty well: https://www.youtube.com/watch?v=z_CyM-Ed8PA
Bikes: Honda CBR600Fi, Kawasaki ER5
PostPosted: 09:58 - 07 Jun 2015    Post subject: Reply with quote
Few if any bikes that I know of specify that the chain should be adjusted under load. The amount of slack specified does vary which should cope with the changes in how much the chain tension changes as the suspension compresses.
K
Az
PostPosted: 10:22 - 07 Jun 2015    Post subject: Reply with quote
K
This could well be the problem then, as I've adjusted the chain first then tightened up the spindle afterwards & then had OH sit on the bike to check the chain tension. Will re adjust and check now. Karma Thumbs Up
Also slightly worrying that I've always done it this way to on the Bandit, so there a high chance I've been riding with a tight chain for the last year and a half Shocked Neutral
Az
PostPosted: 10:51 - 07 Jun 2015    Post subject: Reply with quote
All done-dided, off to Matlock I go Smile
PostPosted: 11:14 - 07 Jun 2015    Post subject: Reply with quote
Thumbs Up for diddley done.
Also +1 on the spindle making a surprising amount of difference. There's essentially no point in my measuring the slack on my GS unless it's done up tight.
iooi
PostPosted: 12:03 - 07 Jun 2015    Post subject: Reply with quote
So clearly a non issue then... Rolling Eyes
klx678
PostPosted: 13:44 - 08 Jun 2015    Post subject: Reply with quote
Vincent wrote:
It may be worth checking your rear wheel bearing and/or drive shaft seal Thumbs Up
I can see it all now...
"Holy Crap, Batman! Shocked the drive shaft is missing!"
It's chain drive... Smile
For the OP. I either load the bike down or use tie downs to pull the rear end into position so the countershaft, swing arm pivot, and axle are in line, the tightest point for the chain run. Then I adjust to get maybe an inch of play. Release the rear wheel to allow full extension again. Measure the play for next chain adjustment to not have to tie it all back down again.
It is better to run a bit loose than too tight. Too tight can damage bearings or break chains. If you look at MX and dual sport bikes they have huge amount of slack, yet they don't throw chains. For a chain to derail it has to be total trash or something causes it. Kind of a lightning strike event.
KLX650 w/Vulcan big bore, over 47K miles
KLX250 for fun and off road
make tensioners for fun and support cycle habits
CaNsA
PostPosted: 13:51 - 08 Jun 2015    Post subject: Reply with quote
The whole system for transferring power to the rear wheel for a chain driven bike, is a Chain Drive.
The drive output shaft is where power is transferred from the engine to the chain drive.
Sload
PostPosted: 23:34 - 09 Jun 2015    Post subject: Reply with quote
Do you not get an equal change for a specified torque? Not predictable?
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
andys675
PostPosted: 15:10 - 10 Jun 2015    Post subject: Reply with quote
if the chain is too tight sat on the bike, stand on the pegs instead Thumbs Up
UrbanRacer
PostPosted: 15:20 - 10 Jun 2015    Post subject: Reply with quote
Lose weight you fat fucking cunt Rolling Eyes
lihp
PostPosted: 17:42 - 10 Jun 2015    Post subject: Reply with quote
Vincent wrote:
And what do you think drives the front sprocket? Rolling Eyes
The output shaft.
The last post was made 11 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 133.42 Kb
