| adam2013 |
 adam2013 Two Stroke Sniffer
 Posted: 20:08 - 02 Jun 2015 Post subject: Just a little problem with my trusty XR 125 |
Hi guys, I've posted on here a few times now and your advice is greatly appreciated and helpful.
So my 2004 XR 125 has done just under 30,000 miles and is still pulling strong in every gear and starts on the button every time regardless of climate.
So the problem is at around 25,000 the bike suddenly locked the back wheel at 20mph, saved it and no traffic so all good. Since then there has been a ticking noise, throughout the rev range. I have no idea what it could be but it is definitely coming from the cylinder upwards.
I fitted a new exhaust at around 27,000(old exhaust had a pen tip sized hole in the down pipe) with new gasket(copper) nuts are tight.
The reason i'm mentioning this is because when I put the baffle in the ticking noise is considerably quieter.
I change the oil every 1000 miles and clean the stainer every time
I use Motul 10 40w semi oil.
Just a quick second question. I bought the bike at 17,500 and I have never checked or adjusted the valve clearances. I was told by the mechanic "the bolts felt like they were going to snap." I would do it myself but he was charging me £10 and i would have had to but a set of feeler gauges.
so My question is should I risk it (but use some heat) and get them bolts of and do the much needed valve clearances check?
Thanks Guys  ____________________ Current: '04 Honda XR 125L
Project: '86 Yamaha DT 125LC |
| Ziggy81scott |
 Ziggy81scott Borekit Bruiser
| Old Git Racing |
 Old Git Racing World Chat Champion
| KrisC |
 KrisC L Plate Warrior
| adam2013 |
| piggoy |
 piggoy Two Stroke Sniffer
| adam2013 |
| adam2013 |
| adam2013 |
 Posted: 18:51 - 04 Jun 2015 Post subject: |
Sorry forgot to mention in the video the ticking starts around 3 seconds in and is on and off(mostly on)
when riding the ticking noise is loudest at around 30mph in 4th
Thanks for all your advice ____________________ Current: '04 Honda XR 125L
| piggoy |
| adam2013 |
| piggoy |
| adam2013 |
The last post was made 11 years, 28 days ago. Instead of replying here, would creating a new thread be more useful? |
