Sinjin94 |
Sinjin94 L Plate Warrior
Posted: 22:24 - 10 Jun 2015 Post subject: Suzuki Gz Marauder 125 Issue |
Hi! Firstly i would like to let you know i am a new rider and many things may be alien to me (im not stupid i promise )
The bike - Suzuki marauder gz 125 2000 model 29000 on the clock and has had new swing arm, new brakes, new cables, new battery, new levers and has just had a service (all done by previous owner who was a mechanic)
The issue -
Went for a ride around the hills in derbyshire all being fine and was largely uphill. after about 40-50 miles i was traveling up hill and the bike started to jump a bit then lost power, after pulling her over and trying to start her up again it wouldnt turn over, after about 20 minutes it turned over but would only stay on briefly and would then cut out, after another 20 minutes it would stay on in neutral and then cut out whenever i tried to pull off in gear. It was at this point i could hear a knocking in the engine ( faint a bit more of a rattle than a loud knock) at a loss another biker stopped and came over who then proceeded to check the spark plug which was quite "sooty" we cleaned that up, popped it back in but the same problem. after getting the bike home and trying it a bit more ive found that:
1. the bike will run, with the faint knocking and with some wildly fluctuating revs
2. when put in first it will cut, even when the clutch is fully pulled in
3. it will pull off in second but only for about 20 ft then cuts
Me , My friends (been riding for a while), and the nice bloke who stopped are at a loss, i think i have included everything and hopefully havent bored you to death with the short life story.
Any suggestions/Questions will be massively appreciated as its my 3rd day riding and feel robbed i cant go out tomorrow haha
Many thanks |
talkToTheHat |
talkToTheHat World Chat Champion
Sinjin94 |
talkToTheHat |
Sinjin94 |
Sinjin94 |
Robby |
Robby Dirty Old Man
Posted: 01:30 - 12 Jun 2015 Post subject: |
This previous owner - are they also a vehicle trader? If so, returning the bike is a possibility, although expect to get a bit of hassle out of them. The favourite excuse would be "that was my personal vehicle, not a trade one, not my problem guv".
If it does need an engine, it isn't the end of the world. Look on ebay for an engine, shouldn't be too expensive. A replacement engine is unlikely to have the same problems, they normally quite reliable, you've just been sold a lemon. Changing an engine in a small bike is very easy - usually 3 or 4 big bolts, a couple of electrical connectors, the drive chain, the carb and the exhaust to remove. No special tools needed, a gentle afternoon's work for someone mechanically competent. |
Sinjin94 |
stirlinggaz |
stirlinggaz World Chat Champion
Sinjin94 |
Taught2BCauti... |
Taught2BCauti... World Chat Champion
Posted: 08:51 - 14 Jun 2015 Post subject: |
Quickest way to get yourself back on the road, would be to replace the engine. Then you could either re-build the old one at your leisure (learning about engines on the way) and swap it back later, or if the old one is too far gone, you could still sell it on eBay as 'needs re-build'.
Either way, you should end up with something to partly offset your original costs. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
The last post was made 8 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
