Suzuki A100
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4, 5  Next
Roflhat
PostPosted: 21:32 - 29 Jun 2015    Post subject: Suzuki A100 Reply with quote
Hi,
new to forum and motorbikes. Just bought my first road bike, a 70's Suzuki A100. I think it's a 73 or 74. It's been off the road since '77 and is a bit rough in places. It has no papers or documents so I'm going to have to look into getting it back on the road. Plan just now is to get it running and registered.
From what I gather these bikes are relatively rare so hopefully I don't need too many parts. I'm used to working on cars and boats, I've recently finished restoring my '68 VW beetle, was a full body off resto which took 4 years.
If anyone has a manual in PDF or otherwise would be greatly appreciated!
Here's a couple photos of the bike as it sits just now:
https://i1013.photobucket.com/albums/af256/Roflhat/IMG_7399.png
https://i1013.photobucket.com/albums/af256/Roflhat/4c8e25fd-954d-43df-ba3a-d066742effc5.png
https://i1013.photobucket.com/albums/af256/Roflhat/00d5d386-c078-46a8-bb24-99a65a663688.png
https://i1013.photobucket.com/albums/af256/Roflhat/cf1cc7d3-e00e-4875-bc8b-dac8ae400d4b.png
I really like the street tracker look, but the bike is growing on me the way it is...
It's lightweight, 83kg dry. I like the idea of a super light bike, so bits might get chopped off.
Cheers,
Seumas
Val
PostPosted: 22:32 - 29 Jun 2015    Post subject: Reply with quote
check manuals section for links to many manuals sites:
https://www.bikechatforums.com/viewtopic.php?t=140295
You can at least see parts fishes here:
https://www.cmsnl.com/suzuki-a100-1976-1977-usa_model15914/partslist/
Roflhat
PostPosted: 09:08 - 30 Jun 2015    Post subject: Reply with quote
That's a brilliant thread, thanks very much!
Managed to find a cheap Haynes manual on ebay for it
cheers
Matt B
PostPosted: 11:26 - 30 Jun 2015    Post subject: Re: Suzuki A100 Reply with quote
If they are getting rare then 'chopping bits off it' seems like the wrong way to go. Would be nice to see it just returned to standard glory Thumbs Up
Roflhat
PostPosted: 12:28 - 30 Jun 2015    Post subject: Re: Suzuki A100 Reply with quote
Yeh I know what you mean, although some things are rare for the wrong reasons!
Having a look at the wiring today, it didn't come with a key so I'm wiring things to the battery for now to try and get it going. My budget is roughly £0 so hopefully it doesn't need too many parts.
Think I might just wire in a toggle switch as a battery isolator instead of the ignition switch.
CBFcarl
PostPosted: 12:49 - 30 Jun 2015    Post subject: Re: Suzuki A100 Reply with quote
Are you gonna stick details of that on the workshop as well?
Sounds funky.
thx1138 wrote: Well if you had a car, I'd bet it would smell like urine had had drunken sex with vomit and made a poo baby.
Polarbear wrote: They are all old now. Probably had more abuse that a Rotherham schoolgirl.
Hellkat wrote: I want to know if Nigella smells of garlic, or just minge.
PostPosted: 14:06 - 30 Jun 2015    Post subject: Reply with quote
Nice original model. Whatever you do keep the paintwork/patina. Assuming the tank can still hold fuel.
I would get it running - you'll likley need to renew a few seals
(kickstart, gear-shaft, crank-etc..) and I bet it needs new points. They wear on the cam 'follower' which makes the timing very tricky - then use it.
Not that rare as they were still building them in Asia (Thailand ?) for years after Japan stopped, BUt that is a nice early one. - mine is 1980 and not so nice.
Good luck
Roflhat
PostPosted: 15:36 - 30 Jun 2015    Post subject: Re: Suzuki A100 Reply with quote
Sounds funky.
I got it when I was 16, near Glasgow. Towed it back home, it was a lot worse than it looked. Ended up doing a complete body off restoration on it. Every single panel has been welded and repaired. New floorpans, bonnet, boot, bottom 10 inches all round have been repaired.
Here it is when I got it:
https://i1013.photobucket.com/albums/af256/Roflhat/rusty2.jpg
New floorpans in:
https://i1013.photobucket.com/albums/af256/Roflhat/floorpan.jpg
Filler was several inches thick in places:
https://i1013.photobucket.com/albums/af256/Roflhat/rusty1.jpg
All new mounts, seals, bolts, everything:
https://i1013.photobucket.com/albums/af256/Roflhat/gearbox.jpg
Here's some photos of how it looks now:
https://i1013.photobucket.com/albums/af256/Roflhat/1391685_653710524673135_1729313720_n.jpg
https://i1013.photobucket.com/albums/af256/Roflhat/IMG_2787.jpg
Lowered 2.5" all round, wider wheels (5.5") with 195 fronts and 205 rears. Front disc brake conversion, eccentric camber nuts, 19mm front anti roll bar, KYB gas shocks all round, the list goes on!
Recently put a 2.0 VW type 4 engine in it, twin 40 kadron carbs, 009 distributor, full stainless exhaust. Drives really well.
It cost all the money I ever earned so this bike has to stay el cheapo!
Roflhat
PostPosted: 15:41 - 30 Jun 2015    Post subject: Reply with quote
Good luck
Cheers. Yeh I'm a fan of the patina of it, as long as it's solid enough. I might sand the tank down a wee bit and clearcoat it to stop further corrosion.
Do you get electronic ignition conversions for these?
That's good news about them not being too rare, hopefully parts will be cheap. I'm going to get it running before spending any money on it.
I was thinking about a K & N air filter, what do you think? I know on beetles folk recommend sticking with the stock one for longetivety.
PostPosted: 16:13 - 30 Jun 2015    Post subject: Reply with quote
No electronic ignition that I know of - some wizzo might have made one but I wouldn't bother. I also tried a pod filter clamped directly to the flange on the carb/clutch cover and it made it worse so I wouldn't bother with that either. Got a bit more power by modifying the exhaust port (wider/higher) and trimming the disc valve and jetting up so now good for an indicated 70... if you're patient.
If you really want to get it screaming then get Mick Abbey to take a look at it and make an expansion. I bet he could get 15 hp out of one..(stock is about 9 I think).
Roflhat
PostPosted: 17:21 - 30 Jun 2015    Post subject: Reply with quote
Alright cool. Glad to hear advice from someone who's been there and done it, saves me money and time!
Modifying it can wait until it's up and running anyhow. Been having some trouble with the wiring. I've removed the ignition switch but I don't know which wires I should attach where. Right now I've put all the wires that were on the ignition (apart from the green one) straight to the positive on the battery and just put and earth from the battery to the frame.
The speedo lights are working, indicators, brake light, headlight all work but when all the wires are attached they're very dim.
When I attach the green wire to the +ve terminal nothing works.
anyone able to point me in the right direction?
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
Roflhat
PostPosted: 21:00 - 30 Jun 2015    Post subject: Reply with quote
NKVD fan wrote:
I used to get bullied when I owned one, had the side panels molested with tippex at college to read gAy100.
Pro tip, the lights and ignition don't run off the battery.
Awful design, the ingest oil through the disc cover and the intake trunk leaks into the gearbox.
Haha unlucky! I might just take the stickers off so that doesn't happen
ah right ok, I was wondering if I could ditch the battery altogether and run the electrics directly off the magneto?
PostPosted: 00:00 - 01 Jul 2015    Post subject: Reply with quote
Don't know if this is correct for your year model. But my wiring diag says for ON postion Red (Battery +6v)connects to orange (neutral light) and green with white (l?) connects to yellow with white (from magneto/generator). OFF position connects black with white to black with yellow..
Black with yellow is direct from the ignition source coil (via contact points ) to coil primary. turning to off position shorts coil primary to gnd in other words. Dont connect B/Y to red !
Leave it open and see if you get a spark at the plug.
I think early models have three gen coils one for ignition source (see above), one for battery charge and one for night running (lights) or something like that. Later models have only two coils one ignition source and one dual purpose with two tappings.
J
PS So no you don't need a battery for it to run.
Roflhat
PostPosted: 09:22 - 01 Jul 2015    Post subject: Reply with quote
Cheers, I'm going to have a look and see if that makes sense!
I'll take a photo of the wiring
Roflhat
PostPosted: 10:29 - 01 Jul 2015    Post subject: Reply with quote
Had another look at it but couldn't match up the wires. Here's the wires from the ignition switch (now removed):
https://i1013.photobucket.com/albums/af256/Roflhat/IMG_7418.jpg
These wires all match up to wires from the harness. Two black wires connect to the solid black wire on the ignition. The black and white wire on the ignition was connected to the -ve battery terminal.
So far I think the orange wire is for the indicators and neutral light and the grey wire is for the headlight and brake light.
PostPosted: 13:38 - 01 Jul 2015    Post subject: Reply with quote
Ok looks like model year differences - that diag I looked at was in the users manual fo 1980 model year. I also have a Haynes somewhere which has older stuff in it..
Suffice to say that I think the ignition circuit should function withou the
ignition switch connected - a bit odd I know.. Did you try for a spark yet ?
J
Roflhat
PostPosted: 21:27 - 01 Jul 2015    Post subject: Reply with quote
J
I've ordered a Haynes manual for it, should be here soon hopefully.
Yeh I think it should too, I just need to figure out where to connect the wires. I've tried for a spark with a few combinations of wires with no success. I've also tried a different spark plug, not the right kind but it should still spark if it's wired right.
Roflhat
PostPosted: 16:24 - 22 Jul 2015    Post subject: Reply with quote
anyone got a spare ingition barrel kicking about?
PostPosted: 22:56 - 22 Jul 2015    Post subject: Reply with quote
[quote="Roflhat"]anyone got a spare ingition barrel kicking about?[/quote
Sorry no pare ignition barrel but..Did you get it started yet ? A spark ?
Roflhat
PostPosted: 09:10 - 23 Jul 2015    Post subject: Reply with quote
not yet m'afraid, haven't had a chance to work on it recently. Still need to have a look at the Haynes manual and figure out how to wire it. I think once I've got it started I may splash out on an ignition barrel, just don't want to put money into it until I know it works
PostPosted: 23:00 - 23 Jul 2015    Post subject: Wiring Reply with quote
OK so I found my Haynes and I think wiring diagram to match your ignition.
As suspected you should be able to start it without the ignition barrel in place.
Pos OFF links Black and Black with White (Batt neg/gnd) together - this shorts
ignition source coil to ground. No ignition switch => no short to gnd of the ignition primary..
Pos ON DAY link batt neg to gnd. Black is free to power coil primary. Green (generator coil output - low level) connects to White with red that charges battery via diode rectifier.
Pos ON Night as day but now Yellow (generator coil output - high level) connects
to both White with Red (battery charge) AND Grey (lights).
That's it.
If it's not sparking without the ignition fitted double check points/timing.
Roflhat
PostPosted: 12:23 - 10 Sep 2015    Post subject: Reply with quote
Sorry havent been on for a while,
thanks for the reply thats really useful, I'll have a go at it this afternoon
Roflhat
PostPosted: 18:18 - 10 Sep 2015    Post subject: Reply with quote
That reply was perfect Very Happy
Got a spark after about 15 minutes of fiddling with the wiring.
Cleaned out the tank then poured fuel in it only to find out there was about 100 pin size holes in it... More like a sieve than a fuel tank.
So i got an old lawnmower tank from my Grandpa and strapped that on. Had a go at starting it but no luck. Think I'll take the carb off and clean it.
https://i1013.photobucket.com/albums/af256/Roflhat/IMG_8295%201.jpg
Papa Lazarou
PostPosted: 21:01 - 10 Sep 2015    Post subject: Reply with quote
Nice bike.
You'll find various tank sealants around. Some are not so good with modern petrol...
Current bike: Honda Blackbird 1100 and a little 250.
The last post was made 8 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 17 - Page Size: 141.07 Kb
