| Dave70 |
 Dave70 World Chat Champion
 Posted: 20:17 - 03 Jul 2015 Post subject: R125 Not starting (Intermittent problem). |
Having some starting issues with my R125 over the past few days.
It started the otber day when leaving work. I pressed the ignition button and it started fine, then within a few seconds the revs dropped and the bike cut out. This happened a couple of times but, was fine after I gave it a few revs on starting up. I should add that on a couplefof those occasions that the bike wouldn't fire up.
Anyway, I rode home (about 20 miles) without further issue.
Then this evening, when setting off for work, it did the same. Sterted up on ignition and then the revs dropped and it cut out, only this time it wouldn't start up again. I tried about 30+ times in the space of around 30-40 minutes and although the electric ignition is trying to fire the engine up, it was having non of it.
So after cancelling work this evening and walking to the shop and back, I decided to try the bike again (this was about 30 mins later) and it started up first time with no problem. I have given it some high revs, let it idle for around five minutes or so and turned it off and restarted it numerous times since and every time it has fired up instantly.
Obviously, something is going on and I don't want to take it for a ride at the moment in case I get stranded.
Anyone have any idea what could be going on?
Apologies for the long post but, I thought it best to give as much info as possible. ____________________ There ain't no devil, there's just god when he's drunk.
2012: R125 killed by white van. 2016 R125 killed by 30,000 miles of redline. Current: 2016 Kawasaki ER6f. |
| RhynoCZ |
 RhynoCZ Super Spammer
| Dave70 |
| RhynoCZ |
 Posted: 21:33 - 03 Jul 2015 Post subject: |
Cheap/disreputable petrol often contains water, dirt and even diesel.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| WD Forte |
 WD Forte World Chat Champion
| Pete. |
 Pete. Super Spammer
| Dave70 |
| Dave70 |
| Old Git Racing |
 Old Git Racing World Chat Champion
| Dave70 |
| Pete. |
 Pete. Super Spammer
| Dave70 |
 Posted: 11:56 - 04 Jul 2015 Post subject: |
I've decided to go ahead and replace the fuel pump, as this seems the most likely problem, according to the interwebs and a mechanic I spoke to this morning and if nothing else it'll rule it out at least.
Popped into my local Yammy dealer before, £128 plus VAT for the part.
Told him I'll be back if I can't source one elsewhere. Ordering one off ebay for £39:99.  ____________________ There ain't no devil, there's just god when he's drunk.
| Dave70 |
 Posted: 12:07 - 09 Jul 2015 Post subject: |
Well, I replaced the fuel injector system yesterday and all seemed good.
However, started it up this morning and the same problem occured again.
Don't really know what is causing the issue now but, although the battery appears fine, I guess I should buy a battery tester and check it out properly.
Once the bike has had a little run out it is starting perfectly, the problem only happen when it's been left for a few hours.
If anyone has any other ideas as to what may be causing the problem, I'd be grateful.
So far I have changed the spark plug, checked the fuel tank for any water or debris and replaced the fuel pump/injector and checked the wires and hoses.
I also gave it a kick this morning ____________________ There ain't no devil, there's just god when he's drunk.
| P.addy |
 P.addy Red Rocket
| Dave70 |
The last post was made 10 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
