suzuki gs125 and ts 125 compatable ?/ts125 wiring diagram
banditruss
PostPosted: 10:44 - 21 Jul 2015    Post subject: suzuki gs125 and ts 125 compatable ?/ts125 wiring diagram Reply with quote
hi all got a cg125 with knackered ignition switch the only ones listed for it are 4/6 wire but this is 9 wire would you know if a ts 125 switch would work as that's the only 9 wire switch i can find...if some ones got a wiring diagram for the ts125 even better so i can check against my wiring diagram for the cg125....the wires on both are same color all but 1 ....
thx for any help russ
There is a gap of 8 years, 63 days between these two posts...
type25dude
PostPosted: 22:04 - 20 Sep 2023    Post subject: Reply with quote
Hi, I know this is an old post, but I wondered if you got sorted. Did you get a diagram for the Ts switch, or how did you resolve the issue. I’m in the same boat for a gs 125 rather than a cg, but same problem.
Any info on what the Ts wires do?
The last post was made 3 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.43 - MySQL Queries: 14 - Page Size: 31.22 Kb
