| livin_in_sinn |
 livin_in_sinn L Plate Warrior
| Flywheel |
 Flywheel Two Stroke Sniffer
| baldy |
 baldy World Chat Champion
 Posted: 16:08 - 10 Aug 2004 Post subject: |
2 strokes run at high revs and have next to no power at low revs. My nsr has this problem so i just keep it above 4000rpm  ____________________ One day i will rule the world, just not today. |
| livin_in_sinn |
 Posted: 17:44 - 10 Aug 2004 Post subject: :) |
thanks for replying, it seems to be like more of a flat spot than i would expect. i mean it begins to rev nice and freely, then sorta dips as it hits those revs.... i've been told not to run it above 6000rpm for at least a few hundred miles as the person who last had it rebuilt the top end. i've been advised by my friend, who has a dt 125 that it shouldnt run like that.
i'll be takin it to a bike repairers soon, and i'm waiting for my haynes manual to come through the post.
and oh yeah, i dunno if it gets done automatically or what, but thanks to whoever moved this post to the right section.
i only rode the bike for the first time on saturday, and its the first time i been on one. i am a speed freak, but only have been going fast in cars. i'll let you guys know what i can do in the bike. but the guy who had it last said he was doing 70mph @6000rpm cruising. and aparantly, thats good for a 125 ns125. ____________________ VTEC |
| baldy |
 Posted: 18:26 - 10 Aug 2004 Post subject: |
If you're just running it it don't go mad with it just yet. Just ride with the revs under 7k for about 1000 miles and then thrash away  ____________________ One day i will rule the world, just not today. |
| Kickstart |
 Kickstart The Oracle
 Posted: 19:28 - 10 Aug 2004 Post subject: |
Restricted it will manage a shade over a true 70mph. Full power it will manage a true 90ish mph.
Normally a 2 stroke with an expansion chamber will have a flat spot at half peak revs, so the flat spot you have sounds at a little too low a revs for that.
How are you opening the throttle? The NSR uses a slide carb so if you just wrench this fully open it will not work properly (there will be virtually no pressure drop through the carb so it will not draw fuel into the air correctly). Open the throttle progressively.
It might be that the jetting is a touch lean at those throttle openings. If so lift the needle up one notch in the carb and see if that improves things.
Twas me who moved the thread by the way.
| ts50x0 |
 ts50x0 Spanner Monkey
 Posted: 19:59 - 10 Aug 2004 Post subject: |
what are you doing at these revs?????? you should be near the redline almost all the time or there is no power. powerband is at 8,000rpm. when your accelerating keep it there!!!!!! youll have lots more fun!  |
| livin_in_sinn |
| livin_in_sinn |
 Posted: 12:33 - 11 Aug 2004 Post subject: |
oh... and many thanks to kickstart for moving the thread to the right place.
The last post was made 22 years, 39 days ago. Instead of replying here, would creating a new thread be more useful? |
