| Gazz |
 Gazz World Chat Champion
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 19:41 - 05 Aug 2015 Post subject: |
If it's only light surface rust you can clean it up with either some fine wire wool or a handful of scrunched up aluminium foil (works very well on chrome).
If it's more heavily rusted with deep pitting then there's no quick fix for it really. ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Sid_The_Sloth |
 Sid_The_Sloth Trackday Trickster
| delsol |
 delsol World Chat Champion
 Posted: 23:45 - 08 Aug 2015 Post subject: |
If only light surface rust then another vote for autosol, can take a lot of time depending on how much you have to polish out.
Horizontal and vertical polishing (using your finger tip or thumb tip) to avoid chaneling, the rag needs to be changed to a clean position every time the rubbing surface of the rag turns black, so small amounts of autosol and lots of clean rag, preferably white.
I don't use any steel wool or scotchbrite etc. or anything other than polishing compounds, even fine emery is going to leave scratches that will need to be polished out.
Gaiters ? Yes deffo.
I used autosol on these fork tubes to take out minor imperfections:
https://www.bikechatforums.com/viewtopic.php?t=305725&highlight= |
The last post was made 11 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
