| mudcow007 |
 mudcow007 World Chat Champion
| Copycat73 |
 Copycat73 World Chat Champion
| mudcow007 |
| Copycat73 |
| mudcow007 |
| Copycat73 |
| mudcow007 |
 Posted: 20:47 - 11 Aug 2015 Post subject: |
well, after an uneventful commute this morning....the bike died about 20ft outside of work
replaced fuse just to get home an it popped 10ft later
replaced again an stuck headlight on (as per copycat's suggestion) an it popped again - so i think i now have killed it
left it in work - fingers crossed its still there tomorrow  |
| mudcow007 |
 Posted: 15:42 - 12 Aug 2015 Post subject: |
still havent been able to get a voltmeter to the bike yet but,
turned the bike on (with a new fuse in) after a few mins the fuse popped with the bike running.
with the kill switch OFF i pulled the 30A fuse out the ignition circuit an as i did i got a few sparks
with the ignition off that circuit shoudl be dead shoudlnt it!? |
| Vincent |
 Vincent Banned
| mudcow007 |
 Posted: 16:14 - 12 Aug 2015 Post subject: |
think ive sussed it
just took the fairings off the arse end - wires look ok
so took the tank off, from what i can see the main loom goes under the tank on the left side an what do i spot with the tank off...
https://i25.photobucket.com/albums/c81/mudcow007/Mobile%20Uploads/20150812_160019_zpsofkazcr2.jpg
a thickish (well thicker than the other wires) red wire has been chaffed by the tank
ive never been so happy to find something damaged before
so any thoughts on how to repair it? |
| Vincent |
 Vincent Banned
 Posted: 16:58 - 12 Aug 2015 Post subject: |
Probably the live for the ignition switch. If you can, solder it. Then shrink wrap. If not, I'd splice a small piece of wire in and, if possible, test continuity on any wire that may be damaged too. Obviously, try and work out why it's chaffing  ____________________ Space Is Deep |
The last post was made 11 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
