Hyosung gv 125 service manual??
cianp005
PostPosted: 09:27 - 09 May 2008    Post subject: Hyosung gv 125 service manual?? Reply with quote
Hi to all. Can anyone send any link for a service manual of the Hyosung GV 125 or even 250 maybe. I acquired such bike for my daily use andneed a service manual to get it running properly as it has been left in a garage for nearly 2 years. Thanka a lot Pete
Timmeh
PostPosted: 09:57 - 09 May 2008    Post subject: Reply with quote
can you speak chinese?
hmmmnz
PostPosted: 10:02 - 09 May 2008    Post subject: Reply with quote
ffs man did you even bother to read the workshop man sticky at the top of the page???? no i thought not,
https://www.4shared.com/file/37311610/40cca90/hyosung-GV125.html
theres the manual, look next time, it only takes a minute
the humans are dead
I kick arse for the lord
cianp005
PostPosted: 10:40 - 09 May 2008    Post subject: Reply with quote
Thanks mate..
There is a gap of 7 years, 104 days between these two posts...
R1stu
Shrek!
PostPosted: 09:45 - 21 Aug 2015    Post subject: Reply with quote
I need this too, link is dead Sad
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
R1stu
Shrek!
PostPosted: 09:46 - 21 Aug 2015    Post subject: Reply with quote
PostPosted: 10:10 - 21 Aug 2015    Post subject: Reply with quote
Change oil, change spark plugs.
Such hard.
R1stu
Shrek!
PostPosted: 15:18 - 21 Aug 2015    Post subject: Reply with quote
Lol, nah bit worse, been sat and only firing on one, trying get carbs out and it not playing ball. I've found the 250 version, so using that, engine is weird, each mounting point as one hex head and one secure torx bolt.
PostPosted: 15:49 - 21 Aug 2015    Post subject: Reply with quote
Firing on 1, coil or lead, could even be plug.
Carbs are standard V twin, undo the clips and yank and wobble.
R1stu
Shrek!
PostPosted: 15:57 - 21 Aug 2015    Post subject: Reply with quote
Got them off now, unfortunately ripped the intake from the mounts rather than from the carb. Had drill snapped bolt out. All done, need to fix the intake mount and put fresh non yellow and green fuel in there. Both plugs sooty, but rear was wet front dry so maybe no fuel was getting to that one.
The last post was made 10 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.37 - MySQL Queries: 14 - Page Size: 64.55 Kb
