2strokestroke... |
2strokestroke... L Plate Warrior
weasley |
weasley World Chat Champion
stevo as b4 |
weasley |
2strokestroke... |
stevo as b4 |
dangerousdave |
dangerousdave Traffic Copper
Posted: 19:37 - 20 Aug 2015 Post subject: Re: kdx n kmx 125 |
2strokestroker wrote: | do I need a press to replace main bearings? |
No, you don't. Its the big-end bearing which is a specialist job, if you don't know what you're doing get a shop to do it.
2strokestroker wrote: | What yr kx USD forks fit if any? |
None are a bolt on replacement. You can take pretty much any year of KX/KXF forks as long as you get the correct size bearings. Given a choice, try and get KXF forks as they are more advanced than earlier versions.[/quote]
Kdx 200 top end go on or is they a kx barrel that will?
Neither will bolt on. I've never heard of anybody making either work.
2strokestroker wrote: | Know about ring intervals n stuff if do this
KX is every 15 hours for piston and rings I believe. KDX200, fix it when its broke, is a real trouper in comparison. |
2strokestroker wrote: | is rear shock re buildable or what kx in will go? |
Shocks can be rebuilt;t, but they are not made to be disassembled, like most OEM shocks. Its the anti-tamper mechanisms, and lack of spares available which makes these more difficult than aftermarket shocks.
No KX shock will go straight in. Have seen a KX shock fitted, but this requires a KX swingers, linkage, and rewarding the top shock mount to the frame as this is totally different on the KX. Saw somebody fit a KTM shock to a KMX125, but with mixed results, and not a clue of what year shock fitted and if any mods were necessary.
2strokestroker wrote: | Kx exhaust? |
Doesn't fit KMX or KDX, they use a spring mounted manifold at the cylinder. The KMX KDX bolts on. Thats the first hurdle. Then fitments to the frame etc.
The main point though is unless you are running a KX engine, then a KX exhaust will do nothing good to the power delvery of a KMX or KDX. They are totally different engines, which need very different exhaust shapes to do their thang.
2strokestroker wrote: | I know could buy kx but wanted a Kdx when new |
Ok, maybe keep the KDX in standard trim them. They are great bikes. Or else buy a KX.
2strokestroker wrote: | n had prob 5 kmxs so.... |
Ok nice.
2strokestroker wrote: | Anyone with a kmx200 barrel n head? |
Pretty rare now as said, I have some spares but holding on to them as don't know when would find another.
2strokestroker wrote: | pref knackered coz be wantin put steel sleeve in anyway |
There's a guy selling sleeved ones with Mitaka pistons and gasket on feebay for 380 quid from Phillipines.
If thats too much keep trawling the bay, they come up eventually
2strokestroker wrote: | n got couple kmx 125 top ends to trade if helps 1 nikasil original n 1 we steel sleeve, |
Most people doing the same as you, wanting to go from 125 to 200. You could flog them and put the money towards a 200 cylinder. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
The last post was made 8 years, 252 days ago. Instead of replying here, would creating a new thread be more useful? |
