| Author |
| The Artist |
 The Artist Super Spammer
 Posted: 18:07 - 26 Aug 2015 Post subject: Electric bike MKII! |
As some of you may know, I commute daily on my electric bike which looked like this, only with a seat mounted tail platform and aluminium box section battery packs strapped to the sides of the frame in the middle. I can't find a picture of it fully assembled.
https://i.imgur.com/txXgh6Z.jpg
Running at about 1800W from the batteries, it was very reliable and considering this was the cheapest ebay chinese motor kit overclocked and under pretty abusive riding, both weight and riding style, it did very well!
Then a couple of mornings ago, I woke up to find this.
https://i.imgur.com/HfJXIvN.jpg
https://i.imgur.com/Mo8EUZX.jpg
https://i.imgur.com/JM0ka0q.jpg
https://i.imgur.com/UBCA3hK.jpg
https://i.imgur.com/gBuV42J.jpg
https://i.imgur.com/BxAP2Sn.jpg
I believe the cause was a short somewhere with the balance leads. I had it configured so 4x 6S batteries were all in parallel to charge so all balance leads combined to 1. The ride home before this happened, it was wet and I think water got into one or more of the connectors and at some point during charging, there were a few sparks and enough heat to melt the insulation on the very small balance leads leading to a chain reaction of insulation melting off the main leads and the ensuing fire. I may be wrong but that seems the most likely because of the rain the day before.
Finally, I stripped off anything useful and here is what is going in the bin or if anyone wants it for a project.
https://i.imgur.com/etnpA8X.jpg
The reason for the new thread, I will be starting my MKII today and I already have gotten hold of a baseline electric bike to start with. I will put those in a new post. |
| Back to top |
| Pete. |
 Pete. Super Spammer
 Posted: 18:20 - 26 Aug 2015 Post subject: |
Wow, never seen a derailleur catch fire before - that's bad luck. Took out your batteries too! ____________________ a.k.a 'Geri'
| Back to top |
| The Artist |
| Back to top |
| The Artist |
 Posted: 19:12 - 26 Aug 2015 Post subject: |
| Back to top |
| Pete. |
 Pete. Super Spammer
 Posted: 19:25 - 26 Aug 2015 Post subject: |
Cool - is that someone's DIY project you've taken over? ____________________ a.k.a 'Geri'
| Back to top |
| The Artist |
| Back to top |
| Wull |
 Wull Crazy Courier
| Back to top |
| The Artist |
| Back to top |
| Wull |
 Wull Crazy Courier
| Back to top |
| kramdra |
 kramdra World Chat Champion
 Posted: 21:42 - 01 Sep 2015 Post subject: |
Very interested to see the result of mk2
Nice to see the battery tubes survived, metal end caps with a strategically placed vent hole might have prevented some melting. I have welded up one end, and bolted the other for access, but not started to use them yet.
Wiring does look... designed for dryer climate Do you leave it charging overnight, unattended?  |
| Back to top |
| The Artist |
| Back to top |
| The Artist |
 Posted: 20:27 - 05 Sep 2015 Post subject: |
Got some bits in the post this week so time for some mods.
https://i.imgur.com/JKkrG5c.jpg
Rear brake upgraded to hydraulic. I actually bought a 180mm disc but it locks up so easy with the 160, there is no need. Also fitted huge long mudguards as this will be used in all weather.
https://i.imgur.com/6OGuijf.jpg
Batteries and controller mounted inside this bag on the frame. Previous owner carried them in his backpack whilst riding and had the controller in a pouch on the frame.
https://i.imgur.com/YICddwt.jpg
Front brake upgraded to 203mm hydraulic from 160mm manual thank god. I can actually stop now. I have actually replaced the forks and neck from my burnt out bike because the ones on this bike were terrible. So here is where things get interesting.
https://i.imgur.com/LixwtB0.jpg
https://i.imgur.com/SYClDJe.jpg
2x twin headlights for more light POWAH. Also got a battery voltage readout display. In that box is a little circuit to step down from 50v to 12v (for fork lights and extras) and then down to 8v for the headlights.
https://i.imgur.com/I9vHZHV.jpg
https://i.imgur.com/XjaSpPQ.jpg
LED strips for the forks for extra visibility as winter is coming.
Things still to do.
Finish off the control box. I am waiting on some waterproof glands for all the wires to go through.
Attach rear red LED strip lights
Clean front forks |
| Back to top |
| The Artist |
| Back to top |
| The Artist |
 Posted: 00:20 - 06 Sep 2015 Post subject: |
| Back to top |
| kramdra |
| Back to top |
| The Artist |
| Back to top |
| chris-red |
| Back to top |
| The Artist |
| Back to top |
| kramdra |
 Posted: 21:28 - 08 Sep 2015 Post subject: |
| Back to top |
| The Artist |
| Back to top |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| Back to top |
| Baffler186 |
 Baffler186 World Chat Champion
| Back to top |
| The Artist |
| Back to top |
| kramdra |
| Back to top |
| The Artist |
| Back to top |
The last post was made 10 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
