massively confused - Fibre broadband
mudcow007
PostPosted: 15:43 - 08 Sep 2015    Post subject: massively confused - Fibre broadband Reply with quote
So just had a fibre leased line from VM installed in work.
So basically VM have given us a Cisco 2921 router, which is fed from a Alcatel switch with a gbic (which the fibre goes into)
VM have given us 2 IPs
62.253.180.110
62.253.180.111
Also to add to the confusion, i have just bought a Sonicwall TZ400
I cant figure how to connect it all into our Lan - which is on 192.168.10.0
the IP's VM have given us our public, but they didnt provide us with Lan details of the Alcatel switch or Cisco router
Am I being stupid here???
do i need another router that will use the Cisco as its gateway that will have the sonicwall in between them all??
panrider_uk
PostPosted: 17:17 - 08 Sep 2015    Post subject: Reply with quote
I'd expect that you would connect the Cisco router to your firewall's wan interface and setup all of your access rules in there (with your lan being connected to the firewall's lan interface) .
Both the Cisco and alcatel will be managed by vm and you won't have any access to them.
mudcow007
PostPosted: 20:12 - 08 Sep 2015    Post subject: Reply with quote
Cheers Pan
I havent even unboxed the firewall yet...will check it out tomorrow
cheers
PostPosted: 21:30 - 08 Sep 2015    Post subject: Reply with quote
Indeed.
That router will want your ext fw interface on their configured port.
You then configure your fw ext address to match that provided by vm and internal addresses on another interface.
That alcatel is likely there to convert fibre to ethernet however that router should have spf capability which is odd... why use the alcatel. Laughing oh well!
mudcow007
PostPosted: 22:11 - 08 Sep 2015    Post subject: Reply with quote
To be honest the Cisco router is a monster (3U!!)......i'm use to using Draytek's an compared to one of them its a beast
it definitely has fibre channels but are unused!?
PostPosted: 22:21 - 08 Sep 2015    Post subject: Reply with quote
Ah well. If they provide and set up the ntu just use that. No real issue.
mudcow007
PostPosted: 11:14 - 11 Sep 2015    Post subject: Reply with quote
am i being a dick here??!
so just had a replacement sonicwall fw as the first one was DOA
just trying to configure WAN settings
VM have given us the IP of the router which is 63.253.180.241
they also said we have the ip address 63.253.180.240 to use
on the Sonicwall wan config, i have set the router as 63.253.180.241 an where it says network i have used 63.253.180.240
the lan is still using the default of 192.168.168.0
i cant ping google from the sonicwall!?
am i being stupid?!??
mudcow007
PostPosted: 11:52 - 11 Sep 2015    Post subject: Reply with quote
yep i was being a dick
problem was 63.253.180.240
set it to 63.253.180.242 an everything is right in the world
Very Happy
The last post was made 11 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 14 - Page Size: 55.15 Kb
