| whitedevil |
 whitedevil World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 14:37 - 16 Aug 2015 Post subject: |
If the oil level is fine and you changed it that long ago I would suspect a wiring fault. Check where it connects to the switch. ____________________ a.k.a 'Geri'
| MattEMulsion |
 MattEMulsion World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 16:31 - 16 Aug 2015 Post subject: |
If the level is OK then it's not low oil level.
Which can only be one of the following:
Low Oil Pressure due to the following:
This could likely be the order of probability
1) Oil Pressure relief valve stuck open.
2) Oil pump failure (gear teeth/ Shaft failure).
3) Oil Pump Suction Port/Pipe/Screen blocked.
4) Main/Big End Bearing completely cufked so the there would be no resistance to pump flow therefore no pressure.
Important Law of Pumping:
Pumps do not Create Pressure. Pumps only Create Flow There is no reasonable argument about this fact.
Most probably stuck relief valve.
If there is an oil level switch then that could be fubar.
There is also a change of an electrical gremlin at work.
So check electrical continuity etc. before you bladder the engine.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| WD Forte |
 WD Forte World Chat Champion
| Pete. |
 Pete. Super Spammer
| CaNsA |
 CaNsA Super Spammer
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
| Pete. |
 Pete. Super Spammer
| MCN |
 MCN Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 21:48 - 16 Aug 2015 Post subject: |
No I recommend stop trying to be clever by regurgitating useless trivia or stop posting a shopping-list of possible faults and pay attention to what the OP has posted.
Not just done an oil change - so not a priming issue that the zx is prone to.
No mention of horrible noises - so not likely to be a pressure fault. If he started the bike without oil pressure he would know it immediately.
That leaves faulty switch or wiring as the probable fault. Possibly the swapped-out clocks. Last thing I would suspect is an actual oil pressure fault based on the lack of audible symptoms. ____________________ a.k.a 'Geri'
| misscrabstick |
 misscrabstick Crazy Courier
| MCN |
 MCN Super Spammer
| Pete. |
 Pete. Super Spammer
| Pete. |
 Pete. Super Spammer
| MCN |
 MCN Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 22:31 - 16 Aug 2015 Post subject: |
| MCN wrote: |
I was smart about the pump and flow in an effort to answer the pressure flow jiz I hear every time someone mentions pump. That's all. |
Okay, then let's run smartly through your diagnostic efforts, because:
| Quote: | Which can only be one of the following: |
Really so you've discounted electrical fault already with no evidence to support, but let's continue...
| Quote: | Low Oil Pressure due to the following:
1) Oil Pressure relief valve stuck open. |
LEAST probable option. See how many examples you can find of it happening.
| Quote: | 2) Oil pump failure (gear teeth/ Shaft failure). |
OP rode home on the bike with no issues, can't be that.
| Quote: | 3) Oil Pump Suction Port/Pipe/Screen blocked. |
Should be number 1 on the list. A leading cause of oil system failure is a blocked strainer.
| Quote: | 4) Main/Big End Bearing completely cufked so the there would be no resistance to pump flow therefore no pressure. |
Again, OP rode home on the bike with no issues. There must be oil pressure so it can't be that. ____________________ a.k.a 'Geri'
| Polarbear |
 Polarbear Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 22:40 - 16 Aug 2015 Post subject: |
The switches on bikes are prone to failing, my 'busa is on it's third and my last bandit has it's switch replaced too. ____________________ a.k.a 'Geri'
| Polarbear |
| stevo as b4 |
| Polarbear |
| MCN |
 MCN Super Spammer
 Posted: 23:01 - 16 Aug 2015 Post subject: |
Hypothesis. Google it.
Based on very limited information (As I have already posted) there are several things that can cause the oil lamp to come on.
Since there is only circumstantial info then an armchair mechanic can't say with 1% accuracy that none of the reasons are impossible.
A sort of vague post (with no disrespect to the OP) got an all-it-can-be response.
I was less nitty-gritty than it is easily possible to be but polarbear and pete, as a tag-team, have taken up the mantle on that one.
I wouldn't normally spend as much time arguing with some cunt/s over a simple oil pressure lamp fault had the machine been in front of me. I would have confirmed the reasons long before now. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN.
| Pete. |
 Pete. Super Spammer
The last post was made 11 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
