Bike of my dreams
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3
bladeblaster
PostPosted: 00:46 - 22 May 2016    Post subject: Reply with quote
I finally got around to replacing the starter clutch.
Sump Off
https://i491.photobucket.com/albums/rr279/bladeblaster/1_zpsyacsigmf.jpg
Oil Pump Out
https://i491.photobucket.com/albums/rr279/bladeblaster/11_zpspihq5jmw.jpg
Lower Case Off
https://i491.photobucket.com/albums/rr279/bladeblaster/111_zps5rygqnlo.jpg
Old Starter Clutch Out
https://i491.photobucket.com/albums/rr279/bladeblaster/1111_zpsbc4rfunj.jpg
The Old Starter Clutch Next To The New Assembled One
https://i491.photobucket.com/albums/rr279/bladeblaster/11111_zpswds5tjo3.jpg
Bottom Case Back On, very fiddly, hopefully everything is back tother properly!!
https://i491.photobucket.com/albums/rr279/bladeblaster/111111_zpsp3u7ujsp.jpg
The rest of the covers that had to come off (all of them) will go back on tomorrow with new gaskets. Ordered new seals for the oil pump as some were a bit shoddy, so that will be a job for the bank holiday weekend.
chickenstrip
PostPosted: 08:47 - 22 May 2016    Post subject: Reply with quote
Dumbski question: you mention the starter clutches have a tendency to stick, what causes this? Some kind of wear?
bladeblaster
PostPosted: 10:58 - 22 May 2016    Post subject: Reply with quote
I think the springs loose their spring, and the rollers get worn
bladeblaster
PostPosted: 20:04 - 06 Jun 2016    Post subject: Reply with quote
Bit of an update.
Whoever painted the engine casings decided it was a good idea to also paint the gasket faces and put it back together with paper gaskets and tacky paint. Evil or Very Mad
So after many hours of scraping, and re-dressing the gasket faces are now as they should be.
https://i491.photobucket.com/albums/rr279/bladeblaster/44444_zpsuvwsfkmb.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/444_zpsrvp6zvol.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/13315383_10153636279259013_2910304170885738930_n_zpsg8jthpvv.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/4444_zpshnppgcpf.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/3_zpss14izx3o.jpg
A blob of silicon sealant on the casing split line
https://i491.photobucket.com/albums/rr279/bladeblaster/33_zpsvqddthc2.jpg
A proper gasket
https://i491.photobucket.com/albums/rr279/bladeblaster/333_zpsh7joxfep.jpg
Clutch case back on
https://i491.photobucket.com/albums/rr279/bladeblaster/33333_zpswno3zrbl.jpg
bladeblaster
PostPosted: 20:12 - 06 Jun 2016    Post subject: Reply with quote
Sump hasn't been off for a while. That's not metal in the filter its congealed rubber from perished seals.
https://i491.photobucket.com/albums/rr279/bladeblaster/2222222_zpsh7ox5lux.jpg
Cleaned up sump
https://i491.photobucket.com/albums/rr279/bladeblaster/222222_zpsqpfmjcom.jpg
Old seal
https://i491.photobucket.com/albums/rr279/bladeblaster/55555_zpsvn4eiels.jpg
New seals
https://i491.photobucket.com/albums/rr279/bladeblaster/222_zpseyp7sjty.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/22222_zpsid05exsj.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/2222_zpstoogpzyo.jpg
af1
PostPosted: 20:44 - 06 Jun 2016    Post subject: Reply with quote
Nice write up . Kawasaki always engineered their bikes so nicely.
Top work....
bladeblaster
PostPosted: 15:50 - 09 Jun 2016    Post subject: Reply with quote
Thanks.
Oil pump and gubbins back in
https://i491.photobucket.com/albums/rr279/bladeblaster/13412175_10153658608069013_6597341344292848603_o_zpsylpmbs1e.jpg
Sump back on
https://i491.photobucket.com/albums/rr279/bladeblaster/13419235_10153658607114013_5764830983756937324_n_zpszrtreghq.jpg
Rocker cover off to do valve clearances
https://i491.photobucket.com/albums/rr279/bladeblaster/13336084_10153658500854013_4243611844591234211_n_zpsgc9ro22f.jpg
bladeblaster
PostPosted: 22:40 - 03 Jul 2016    Post subject: Reply with quote
Valve Clearances done
https://i491.photobucket.com/albums/rr279/bladeblaster/00_zpsdidlt2yy.jpg
New seals
https://i491.photobucket.com/albums/rr279/bladeblaster/000_zpse0avsowc.jpg
Rest of the engine covers back on with new gaskets and seals
https://i491.photobucket.com/albums/rr279/bladeblaster/0000_zpse83qlxhx.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/00000_zps086cfmkt.jpg
https://i491.photobucket.com/albums/rr279/bladeblaster/000000_zpstr5asl1q.jpg
engine back in frame
https://i491.photobucket.com/albums/rr279/bladeblaster/0_zpslmz0q3fs.jpg
Now I just have to remember how everything was connected up Laughing
bladeblaster
PostPosted: 22:38 - 12 Jul 2016    Post subject: Reply with quote
exhaust back on, which was much harder than it should have been, and I have no idea why. Bit of a bastard to get everything lined up.
https://i491.photobucket.com/albums/rr279/bladeblaster/12345_zpsqo153x7r.jpg
Sub frame and oil cooler back on (temporarily at least)
https://i491.photobucket.com/albums/rr279/bladeblaster/123456_zpslsrhpzob.jpg
Then had to take that back off, because its almost impossible to put the feed pipe from the rad to water pump back with it fixed in place. In addition to that the rad has to be located on the sub frame then the whole thing swung up into position, otherwise the rad won't locate properly. Rolling Eyes
All back together
https://i491.photobucket.com/albums/rr279/bladeblaster/1234567_zpsqvftb8hh.jpg
Front sprocket cover and hydraulic clutch cylinder back on, electrics all connected back up, with the exception of the starter motor because I have lost the nut.
https://i491.photobucket.com/albums/rr279/bladeblaster/1234_zps3aylify3.jpg
Then next step is reconnect the starter motor, air box back in, then fill her up with oil and coolant, and then the moment of truth. Should be done this weekend.
There is a gap of 343 days between these two posts...
pompousporcup...
PostPosted: 11:12 - 21 Jun 2017    Post subject: Reply with quote
did you ever get this one running again?
The last post was made 6 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 17 - Page Size: 73.88 Kb
